Results 1 to 9 of 9
    Full Member level 2
    Points: 1,053, Level: 7
    Jan 2018
    144
    1,053
    7
    Need help on I/O single stub match for LNA.
    Since I am designing a single stub match at the input and output of my LNA design. Is it okay to add a small amount of extra line at the end, so when I connect the SMA connectors they can use the extra small amount of line to solder onto and also so the upper ground left and right bars of the SMA do not touch the stubs (since my stubs will be at the ends of the lna pcb)? Or would you consider using two section tline?
    Full Member level 2
    Jan 2018
    144
    1,053
    7
    Difference between a two section tline and a single stub?
    I am trying to design a single stub microstrip line on pcb, but I'm confused about the diagram and feel the drawing might be misleading as shown here: https://www.google.com/search?q=sing...3wU4125vAl-K4M
    When you design a single stub matching network, all that is needed is d(distance of the main line), l(length of the stub), and the load, but how do you know the length of the line before the stub in the drawing? Wouldn't the T shape of the line actually be the same as a two section tline instead? Or can the main line (d as shown in the Google image above) vary between the stub, such as shown in this picture: https://www.google.com/imgres?imgurl...1&vet=1&w=1280.
    Points: 264,335, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,187
    264,335
    100
    Re: Difference between a two section tline and a single stub?
    Look thoroughly at the drawing. One side of the "main line" is terminated with Z0, the other with an arbitrary impedance ZL which has to be matched to Z0. The ZL side acts as impedance transformer, its length matters.
    Full Member level 2
    Jan 2018
    144
    1,053
    7
    So, right before the stub (on the Z0 side) can be any length of line, but has to equal Z0 (50 ohm)? Or would it have to be the 50 ohm SMA connector and if so, how much extra copper line can I add before the SMA connector?
    Points: 34,414, Level: 45
    Oct 2001
    4,918
    34,414
    45
    Here is not about "how much extra copper line can I add before the SMA connector".
    You can make initially the line to be 50 ohms, and in your simulator tune its length (and position in regards to SMA connector) until you get the desire performance (S11, S22, S21, etc).
    Sometime to get the performances the circuit might need to tune the line width as well..
    Full Member level 2
    Jan 2018
    144
    1,053
    7
    Quote Originally Posted by vfone View Post
    How bout theoretically?
  7. #7
    Full Member level 2
    Points: 1,005, Level: 7
    Jun 2018
    Turkey
    144
    1,005
    7
    Quote Originally Posted by skatefast08 View Post
    Theoretically, use reflection coefficient and smith chart using wavelength and frequency of interest as inputs. You need to make your reflection coefficient as good as possible to reduce the reflections between Z0 and Zl ( hence low Standing wave ratio )
  8. #8
    Points: 34,386, Level: 45
    Dec 2004
    New England, USA
    4,823
    34,386
    45
    The whole concept of "Impedance Matching" was developed so that you could add arbitrary lengths of line at the input and output of a circuit component, and not see any performance degradation. But to do that the component, an LNA in this case, has to first be matched to the characteristic impedance of the line you want to use. Normally that is 50 ohms, so do your match at the input to 50 ohms, and the match at the output to 50 ohms, then you can add all the line length of 50 ohm microstrip you desire!
    In some rare cases, you might not match to 50 ohms...like if the LNA is driving a bandpass filter, and the bandpass filter components are easier to realize in a 20 ohm system....
  9. #9
    Newbie level 3
    Points: 197, Level: 2
    May 2018
    197
    What exactly do you mean by impedance transformer and how does this apply to his design?
    Dude, the two pictures are different stubs, the first one is shunt stub and the second one is a series stub.
    https://www.google.com/search?q=sing...yhYRPWvjBzv3M:
