Results 1 to 6 of 6
    Points: 1,257, Level: 8
    Dec 2013
    49
    1,257
    8
    Problem in using Verilog-a in hspice
    hi
    i wanted to run a simple verilog-a in hspice 2013 that are as below:
    Content of resistor.va as:
    // Simple resistor
    `include "disciplines.vams"
    module resistor(p,n);
    parameter R=1.0 from (0:inf);
    electrical p,n;
    analog I(p,n) <+ V(p,n)/R;
    endmodule
    Content of resistor.sp file as:
    *Title: Simple Verilog-A Resistor
    .hdl resistor.va
    .options post=1
    X1 1 2 resistor r=1
    *r1 1 2 1
    r2 2 0 1
    VS 1 0 1
    .dc VS 0 10 1
    .probe v(2)
    .end
    when i run resistor.sp in hspice , some file is produced but .lis file is empty( 0kb) and nothing is written on it and nothing occurred.
    i search this site and search net. in some thread, the problem is related to licence, but i don't know how to check it or correct it.
    for clarity, i write the name of files created after runing hspice:
    • resistor.sto
    • resistor.valog
    • resistor.lis
    • resistor.pvadir(folder)
    please guide me
    Points: 39,139, Level: 48
    Mar 2008
    USA
    6,327
    39,139
    48
    Re: Problem in using Verilog-a in hspice
    There should be a log file, I'd think, and there you would find
    clues about what it didn't like (and if you're lucky, why). Or
    some barf-wad in the console / control window, depending
    on what your version looks like.
    From what I've seen, there is usually an intermediate step
    in using veriloga models, taking them to a C compiled model
    that SPICEs tend to support directly (code models). I see
    no discussion of this in your problem description, whether
    it succeeds, fails or never even is tried. I have seen that
    some SPICEs manage this, and some expect you to go and
    do the compile and link in the object model yourself.Check
    the HSPICE docs about that.
    Dec 2013
    49
    1,257
    8
    Content of resistor.valog as :
    |          Synopsys Unified Verilog-A (pVA v3.0)         |
    |              Machine Name: DESKTOP-FNK1C3V             |
    | Copyright (c) 2013 Synopsys Inc., All Rights Reserved. |
    libepva built by hspmgr synmake_pva_build  on Wed Jul 24 10:18:53 CST 2013
    HSP_HOME:   C:\synopsys\Hspice_H-2013.03-SP2
    HSP_ARCH:   win64
    HSP_GCC :   C:\synopsys\Hspice_H-2013.03-SP2\GNU\win64\bin\gcc
    HSP_GCC_VER:   3.4.5
    Working-Dir: C:\Users\safir rayaneh\Desktop\veriloga-hspice
    Args:        -p hsp -t spi -f resistor.pvadir/pvaHDL.lis -o resistor.pvadir
    ### optimize mode ###
    Args: pva -p hsp -t spi -f resistor.pvadir/pvaHDL.lis -o resistor.pvadir
    Begin of pVA compiling on Fri Dec 07 11:31:02 2018
    Parsing './resistor.va'
    Parsing include file 'C:/synopsys/Hspice_H-2013.03-SP2/include/disciplines.vams'
    End of pVA compiling on Fri Dec 07 11:31:02 2018
    End of build pVA DB on Fri Dec 07 11:31:02 2018
    *pvaI* Module (resistor): 2 unexpanded port, 0 init, 1 behav, 1 contrib, 11/0 expr(s)
    *pvaI*        No DIS, 0 afCount, 0 MT
    *pvaI*        1 const-G and 0 const-C, No switchBranch, 0 bypassOpt
    *pvaI*        generated 0 flow node(s) during compilation.
    End of pVA genC on Fri Dec 07 11:31:05 2018
    *pvaI* #### Total 99 line-size(s), 11/0 expr(s), 1 contr(s), 0 init(s), 1 behav(s), 2 port(s)
    Generating resistor.pvadir\pvaRTL_win64.dll
    pVA concluded on Fri Dec 07 11:31:29 2018
    Dec 2013
    49
    1,257
    8
    in resistor.lis file, it is found:
    Init: read install configuration file: C:\synopsys\Hspice_H-2013.03-SP2\meta.cfg
    **error** call to epvaHDLinit failed.
    **error** Failed to read Verilog-A file, see .valog file for details.
    **error** (resistor.sp:2) difficulty in reading input
    but file resistor.valog did not be open with notpad++ and other apps.
    Mar 2008
    USA
    6,327
    39,139
    48
    The compilation appears to have finished with no complaints,
    but seems the "real deal" cannot be read. Possibly you need
    to tell HSPICE where to look for this
    "resistor.pvadir\pvaRTL_win64.dlldll" file
    or that it needs to look, in the first place? I dunno.
    Dec 2013
    49
    1,257
    8
    hi dick_freebird
    can uoy explain more? suppose you are right, what do i do?
