Converting Verilog to VHDL
engr_joni_ee
Advanced Member level 3
Is there any tool exist which convert Verilog to VHDL ?
A google search would have helped you
But why do you want to? all tools allow mixed language.
I have found a working example in Verilog and I need to modify it but I need to do it in VHDL rather then Verilog.
WhI checked vendor's tool are you planning to use?
Why? All tools accept both languages. Maybe this gives the opportunity to learn Verilog? its not that hard to do if you understand VHDL.
Hi again,
I can understand the I/O Deceleration and most of the code but the code in between where signals and variable are defined is difficult in Verilog. Can someone please explain or translate into VHDL ?
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
reg [C_AXIS_TDATA_WIDTH+2-1:0] mem[(2**ADDR_WIDTH)-1:0];
reg [C_AXIS_TDATA_WIDTH+2-1:0] mem_read_data_reg = {C_AXIS_TDATA_WIDTH+2{1'b0}};
reg mem_read_data_valid_reg = 1'b0, mem_read_data_valid_next;
wire [C_AXIS_TDATA_WIDTH+2-1:0] mem_write_data;
reg [C_AXIS_TDATA_WIDTH+2-1:0] m00_data_reg = {C_AXIS_TDATA_WIDTH+2{1'b0}};
reg m00_axis_tvalid_reg = 1'b0, m00_axis_tvalid_next;
// full when first TWO MSBs do NOT match, but rest matches
// (gray code equivalent of first MSB different but rest same)
wire full = ((wr_ptr_gray_reg[ADDR_WIDTH] != rd_ptr_gray_sync2_reg[ADDR_WIDTH]) &&
             (wr_ptr_gray_reg[ADDR_WIDTH-1] != rd_ptr_gray_sync2_reg[ADDR_WIDTH-1]) &&
             (wr_ptr_gray_reg[ADDR_WIDTH-2:0] == rd_ptr_gray_sync2_reg[ADDR_WIDTH-2:0]));
// empty when pointers match exactly
wire empty = rd_ptr_gray_reg == wr_ptr_gray_sync2_reg;
// control signals
reg write;
reg read;
reg store_output;
assign s00_axis_tready = ~full & ~s00_rst_sync3_reg;
assign m00_axis_tvalid = m00_axis_tvalid_reg;
assign mem_write_data = {s00_axis_tlast, s00_axis_tdata};
assign {m00_axis_tlast, m00_axis_tdata} = m00_data_reg;
]reg [C_AXIS_TDATA_WIDTH+2-1:0] mem[(2**ADDR_WIDTH)-1:0];
use signal and a std_logic_vector array type.
mem_read_data_reg is assigned an initial value of all 0's
This isn't correct, I'm suprised it compiles {} should be around the RHS stuff for concatenate.
combined signal declaration of full and a continous assignment, in vhdl you will make a signal of std_logic, and then assign full with the RHS stuff.
!= is /=
&& is logic AND
== is =
~ is NOT
& is bit-wise AND
in VHDL
signal m00_axis_tvalid : std_logic;
m00_axis_tvalid <= m00_axis_tvalid_reg;
{ , } is & (contatenate)
I don't think there is an equivalent in VHDL just assign the slices of m00_data_reg to the two LHS signals, you can use the 'left, 'right stuff to get the indicies to use based on the LHS signals.
Is it possible to use 'signal' in VHDL in place of 'wire' and 'reg' in Verilog ?
The following syntax is confusing.
parameter ADDR_WIDTH = 12,
parameter C_AXIS_TDATA_WIDTH = 32
It create a reg 'mem' but the dimension 2^12 - 1 = 4096 - 1 = 4095 is not the same in LHS. Any explanation on this ?
Why it is not written as
Also in the following. Is it defining two reg 'mem_read_data_valid_next' and 'mem_read_data_valid_reg' ? If yes then what are the dimensions of both ?
Yes
this is an array declaration - 4096 words (assuming ADDR_WIDTH = 12) @ (C_AXIS_TDATA_WIDTH+2) bits for each word
equivolent to this:
type ram_t is array(2**ADDR_WIDTH-1 downto 0) of std_logic_vector(C_AXIS_TDATA_WIDTH+2-1 downto 0);
signal mem : ram_t;
You really should look into a verilog tutorial.
I would like to include Verilog source code in VHDL testbench but I get some errors in component deceleration in VHDL testbench.
Verilog source code
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
module axis_fifo_v1_0 #
    input  wire                   s00_axis_aclk,
    input  wire                   s00_axis_aresetn,
    input  wire [C_AXIS_TDATA_WIDTH-1:0]  s00_axis_tdata,
    input  wire [(C_AXIS_TDATA_WIDTH/8)-1 : 0] s00_axis_tstrb,
    input  wire                   s00_axis_tvalid,
    output wire                   s00_axis_tready,
    input  wire                   s00_axis_tlast,
    input  wire                   m00_axis_aclk,
    input  wire                   m00_axis_aresetn,
    output wire [C_AXIS_TDATA_WIDTH-1:0]  m00_axis_tdata,
    output wire [(C_AXIS_TDATA_WIDTH/8)-1 : 0] m00_axis_tstrb,
    output wire                   m00_axis_tvalid,
    input  wire                   m00_axis_tready,
    output wire                   m00_axis_tlast
Here is VHDL testbench
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
entity axis_fifo_v1_0_tb is
end axis_fifo_v1_0_tb;
architecture Behavioral of axis_fifo_v1_0_tb is
component axis_fifo_v1_0
generic(
     ADDR_WIDTH         : integer := 12;
     C_AXIS_TDATA_WIDTH : integer :=  32
port (
    s00_axis_aclk     : in  std_logic;
    s00_axis_aresetn  : in  std_logic;
    s00_axis_tdata    : in  std_logic_vector(C_AXIS_TDATA_WIDTH-1:0);
    s00_axis_tstrb    : in  std_logic_vector((C_AXIS_TDATA_WIDTH/8)-1 : 0);
    s00_axis_tvalid   : in  std_logic;
    s00_axis_tready   : out std_logic;
    s00_axis_tlast    : in  std_logic;
    m00_axis_aclk     : in  std_logic;
    m00_axis_aresetn  : in  std_logic;
    m00_axis_tdata    : out std_logic_vector(C_AXIS_TDATA_WIDTH-1:0);
    m00_axis_tstrb    : out std_logic_vector(C_AXIS_TDATA_WIDTH/8)-1 : 0);
    m00_axis_tvalid   : out std_logic;
    m00_axis_tready   : in  std_logic;
    m00_axis_tlast    : out std_logic
end component;
begin
end Behavioral;
I am facing problem in converting
assign mem_write_data = {s00_axis_tlast, s00_axis_tdata };
in to VHDL.
  if ( (not(full)) and (not (s00_rst_sync3_reg))) then
  s00_axis_tready <= '1';
  else
  s00_axis_tready <= '0';
  end if;
The error I get is
 # ** Error: E:/temp/ip_repo/hdl/AXIS_v1_0.vhd(154): Type error resolving infix expression "and" as type std.STANDARD.BOOLEAN.
Also the following I am not sure if it is correct.
  if ((wr_ptr_gray_reg(GC_ADDR_WIDTH) /= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH)) and
             (wr_ptr_gray_reg(GC_ADDR_WIDTH-1) /= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH-1)) and
             (wr_ptr_gray_reg(GC_ADDR_WIDTH-2 downto 0)= rd_ptr_gray_sync2_reg(GC_ADDR_WIDTH-2 downto 0))) then
			 full <= '1';
			 else
			 full <= '0';
			 end if;
  if (rd_ptr_gray_reg = wr_ptr_gray_sync2_reg) then
  empty <= '1';
  else
  empty <= '0';
  end if;
Can anyone please check this ?
Consider that boolean and std_logic are different data types. VHDL "if" statement needs boolean expression.
Still something is not clear. I have converted a Verilog statement to VHDL.
s00_axis_tready <= not (full) and not ((s00_rst_sync3_reg));
Is the above conversion is correct ?
A quick way to check would be to run synthesis on each of the two codes and then compare the resulting circuits in RTL viewer.
The problem is that the code is big and I need to write VHDL for the whole code. I have done most of it but have some Verilog statements on which I have a doubt.
Here is another. Can someone please look at the following conversion and also in my last post.
  empty <= '1';
  else
  empty <= '0';
  end if;
Both are correct for std_logic data type. To keep the boolean expression to std_logic conversion (post #19) compact, you may use a conversion function.
Code VHDL - [expand]
empty <= bool_to_std_logic(rd_ptr_gray_reg = wr_ptr_gray_sync2_reg);
