Results 1 to 8 of 8
    Points: 30,735, Level: 42
    Sep 2008
    cambridge
    6,423
    30,735
    42
    Potting compound to cover up components to thwart reverse engineering?
    We have some all SMD, offline led driver PCBs and we want to cover up the control circuitry with opaque “potting” compound so that its harder for people to reverse engineer our product.
    We need the potting to be really gluey and sticky, but not pressurize the smd caps and resistors and TSSOP10, SOT23 etc IC’s that it will cover.
    Is it cheaper to just get the whole PCB covered, rather than just odd patches?
    Do you know of a potting compound which is good for this?
    The PCB is about 70mm by 120mm and has components only on the top.
    •   AltAdvertisment
    Full Member level 5
    Points: 1,248, Level: 7
    Aug 2016
    269
    1,248
    7
    Re: Potting compound to cover up components to thwart reverse engineering?
    There should be compounds specifically made to make it difficult to RE a product.
    https://www.keypolymer.com/potting-encapsulating/
    its a really expensive measure to implement.
    •   AltAdvertisment
    Points: 8,427, Level: 21
    d123's Avatar
    Jun 2015
    1,502
    8,427
    21
    Why not remove the IC identifiers instead by sanding or scraping or whatever it is manufacturers do to the letters/numbers? That's quite typical to prevent reverse engineering, isn't it?
    •   AltAdvertisment
    Points: 75,009, Level: 66
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,294
    75,009
    66
    or... if you are dealing in large quantities, ask the manufacturer to use your own ID on them, not necessarily a logo but a number you know but the competition don't.
    Makes stock control easier. There's nothing worse than junking a box of ICs because you sanded them then forgot what they were!
    Sep 2008
    cambridge
    6,423
    30,735
    42
    Thanks...
    Our volumes are only small, and this is only for small orders , where we suspect reverse engineers are ordering small qtys from us for that reason
    Also, we find the "key ploymer" ones a little expensive, and wish to try and use some of our in-house glues and epoxies as follows.....
    Does anyone know if there are any hazards involved with potting electronics components (not “power” components, rather, just “signal” components, eg low power opamps and SMD resistors and capacitors) with any of the following glues/compounds?
    (this is just for covering up components to make reverse engineering harder)
    Loctite EA 9497
    http://www.loctite.co.uk/loctite-408...edTab=document
    Loctite EA 9492
    http://www.loctite.co.uk/loctite-408...=8802629320705
    Pro-Power EGPE500GF
    http://www.farnell.com/datasheets/514062.pdf
    We think there may be problems with…
    1…..Corrosion of electronics component bodies.
    2…..Tough glues curing aggressively and pulling SMD resistors off the PCB, aswell as cracking SMD ceramic capacitors
    3….Air gas getting left in the potting, which may mean future mini explosions in the potting due to expansion of the trapped air.
    Do you agree?....ie we need more specialised and specifically labelled, “electronics component potting” compounds?
    unfortunately the datasheets dont tell of the suitability for SMD electronics potting.
    •   AltAdvertisment
    Advanced Member level 2
    Points: 4,703, Level: 16
    ZASto's Avatar
    Jan 2008
    Messy Corner, 44°47'31.56"N, 20°28'9.16"E
    551
    4,703
    16
    Treez, if somebody wants to reverse engineer your product, chances to protect your board are slim. Unless you are using microcontroller that can not be microprobed, potting will jus slow down reveng for maybe a day or less.
    Make no mistake between my personality and my attitude.
    My personality is who I am.
    My attitude depends on who you are.
  7. #7
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,294
    75,009
    66
    Your products must run mighty hot!
  8. #8
    Points: 15,058, Level: 29
    Nov 2012
    2,786
    15,058
    29
    Epoxy is usually very hard to remove (most plastic ICs are epoxy encapsulated) and if you mix some dark pigments, it will be more effective. But remember the old saying: nothing can be made foolproof because fools are very smart!
