Results 1 to 5 of 5
    Junior Member level 2
    Points: 1,127, Level: 7
    Sep 2013
    21
    1,127
    7
    power (W) sum of series & parallel circuit.
    i will design series circuit with resist.
    each of 10 resist consist of series circuit.
    i know power sum of parallel circuit
    but what is the allowable power of each of resist.
    and i don't know mathmatic formula
    Points: 16,344, Level: 30
    Nov 2012
    2,992
    16,344
    30
    Re: power (W) sum of series & parallel circuit.
    Yes, power will be additive.
    In both series and parallel combinations, you can add the individual power dissipated by individual components to get the total.
    Sep 2013
    21
    1,127
    7
    how to calculate mathmedical formula of power sum?
    Advanced Member level 1
    Points: 2,387, Level: 11
    Aug 2016
    414
    2,387
    11
    You have calculated correctly the power dissipated by each resistor in each case.
    However, in engineering you have to leave a safety margin when selecting components. Ideally, the higher the safety margin the better, but practically, there is a cost (and size) implication so you have to strike a balance between the two. After calculating the power dissipation (say P) like you did, different folks use different safety factors to obtain the minimum power rating for the resistor. There are factors like 1.25*P; 1.3333*P; 1.5*P and so on. Here, 1.25*P gives the least safety margin and 1.5*P gives the most. I go for 1.5*P.
    --Akanimo.
    Points: 74,683, Level: 66
    Apr 2014
    15,143
    74,683
    66
    Why? What's your aim?
    Every electronic part has a datasheet. It tells you the specifications and the testing parameters.
