Results 1 to 3 of 3
    Junior Member level 1
    Points: 390, Level: 4
    Jun 2017
    18
    390
    VCO improve tuning range
    Hello, I am designing a quadrature VCO but I can't achieve wide tuning range.. Which do you think is the best way to do so? I use a simple LC-tank topology.
    •   AltAdvertisment
    Points: 38,027, Level: 47
    Mar 2008
    USA
    6,143
    38,027
    47
    Re: VCO improve tuning range
    All you have to work with is the Cmax-Cmin range of the varactor,
    as a fraction of total node C. Scaling varactor up and inductor
    down, and minimizing size of anything connected to the tank,
    is about all you have for "knobs".
    •   AltAdvertisment
    Jun 2017
    18
    390
    I would like to make tuning range 2.5to5GHz and I wonder if a capacitor bank will work or not ..Also I have a question about signals on switches.. should they be something like different clocks ? like bit0->clk, bit1->clk/2 etc (clk signal from a vpulse) Click image for larger version.
