Results 1 to 5 of 5
    Full Member level 1
    Points: 2,619, Level: 11
    Jun 2008
    99
    2,619
    11
    Convert SC16IS752 module to handle higher baud rates
    I bought several of these SC16IS752 DUART modules on Aliexpress to use with my C8051F340 projects but was dissappointed to find the crystal they came with could not handle baud rates above ~57600. So ... I bought some 29.4912 MHZ crystals swapped out the crystals.
    I first used solder wick to get out most of the solder, then gently rocked the large crystal side to side until it came loose. I tested it all the way up to 460800 baud ... works fine !
    Points: 82,022, Level: 69
    Apr 2014
    16,651
    82,022
    69
    Re: Convert SC16IS752 module to handle higher baud rates
    And what's your question, now?
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    Full Member level 1
    Jun 2008
    99
    2,619
    11
    Oh ... didn't copy other half of message :(
    I am really looking for readily available I2C/SPI - to - 4 UART bridges ... or small 8051/STM8/32 micro development boards with at least 4 hard ware UARTs. My searches haven't turned up anything. Does anyone know of any ?
    Thanks in advance.
    Apr 2014
    16,651
    82,022
    69
    What I did:
    * opened farnell.com in the browser
    * did a search for UART
    * selected the interfaces chips
    * selected "4 UARTs"
    And found MAX14830.....and many others within one minute
    What did you so far?
    Full Member level 1
    Jun 2008
    99
    2,619
    11
    Ohhhh Bless you sir, bless you.
    And the MAIN POINT .... development boards ????
