Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Points: 30,725, Level: 42
    Sep 2008
    cambridge
    6,421
    30,725
    42
    Re: Two Switch Forward + PFC SMPS design in progress
    Anyway, like you can see, i gave it an np/ns of 10....
    so you can choose 60/6, or 120/12, etc etc
    choose whatever number of turns you like , as long
    as
    1...you have the right np/ns
    2...you have whole numbers of turns for np and ns
    3....You dont dissipate too much in the wires of the coils
    4...you dont overheat the core with core losses.
    5....you dont saturate the core
    6...the turns fit on the core
    7...you can terminate the turns to the former
    8...mind out for skin effect
    So you could use a layer of approx 0.5mm wire for the pri if choosing 60 turns...
    and then you could have a few parallel strands for the sec...and spiral wind them across the bobbin so that the turns are evenly spread across the bobbin..
    ..this tends to increase coupling between pri and sec.
    If your number of tunrs is low, then you often have ti use paralle strands to get the coil layer to fit the bobbin width...but as discussed , you can always do spiral winding.
    •   AltAdvertisment
  2. #22
    Member level 3
    Points: 1,995, Level: 10
    Jul 2009
    Australia
    58
    1,995
    10
    Thanks again for all your help, I haven't yet had a real chance to fully study your examples, on first look they appear to make sense so far.
    •   AltAdvertisment
  3. #23
    Sep 2008
    cambridge
    6,421
    30,725
    42
    The excel design sheet shows i considered it as a transformer isolated buck converter.....(which is what a 2tf is)
    I took the condition of min vin and Continuosu conduction mode.
    I then selected the max Duty cycle.
    I then calculated what the "effective vin" would be, in order to achieve the vout with that "effective vin".
    I then calculated what turns ratio would be needed to give me that "effective vin" from the actual vin.
    ...when i then did the transformer design, i ended up adjusting the max duty to suit the transformer design.......(i was juggling the amount and thickness of turns etc etc)
    The overall equation for a 2tf is vout/vin = ND, where N = NS/NP (that of course assumes continuous conduction mode)
    i think when you first do it....you just have to jump in, make a mess of it....and then start correcting it...or start over, and over.
    Use the simulator to check your calculations.
