Results 1 to 4 of 4
    Newbie level 2
    Points: 56, Level: 1
    Oct 2018
    56
    DFT interview questions
    1. EDTbypass is passing. EDT chain patterns are failing. What could be the reasons.
    2. Two subchips are there. Shifting power is huge. HOw to reduce power dissipation?
    What are the options you have, without affecting coverage and test time? (HW or SW
    options).
    3. Setup vioations are there in your design. Which patterns would fail? (s@ or @speed?)
    4. Hold vioations are there. Which patterns would fail?
    5. Hold vioations are there. Which patterns would fail?
    6. Two flops will have the same values during shift. Whats the effect of it?
    7. Where do we use parallel testbench? Whats the use of parallel simulations?
    8. If you have simulations failures, what are the things you would look at?
    9. In synthesis, if area is not meeting the target, what would you do?
    10. If some flops in two clock domains are failing, (S@ patterns), and those failures are
    expected.HOw would you make them pass them on silicon? (no design changes are
    allowed.
    11. Atspeed coverage is always less than STUCK-at coverage. Why?
    12. P1500? are you aware of it?
    13. AND gate - optimal input pattern set to detect all S@ faults.
    14. What are EDT aborted faults?
    15. DRCs in ATPG
    •   AltAdvertisment
    Points: 68,704, Level: 63
    Apr 2014
    14,021
    68,704
    63
    Re: DFT interview questions
    What have you done so far?
    What are your ideas?
    What is your undestanding?
    •   AltAdvertisment
    Points: 7,284, Level: 20
    Apr 2016
    1,544
    7,284
    20
    Quote Originally Posted by Nitin1245 View Post
    options).
    allowed.
    15. DRCs in ATPG
    so many mixed concepts and contexts in one post.
    Really, I am not Sam.
    •   AltAdvertisment
    Newbie level 6
    Points: 377, Level: 4
    Mar 2017
    13
    377
    options).
    allowed.
    15. DRCs in ATPG
    All about SCAN, how's about MBIST, LBIST or BSCAN ?
