Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Junior Member level 1
    Points: 841, Level: 6
    Oct 2014
    19
    841
    Re: Best Way to Implement Shared RAM
    Sorry, no, I miswrote.
    There will never be two modules that need to write the same bit at the same time (hence the merged A/B write), however one module may write it and another module may read it. This is in addition to read access via the "external" interface to my core.
    •   AltAdvertisment
  2. #22
    Points: 67,586, Level: 63
    Apr 2014
    13,823
    67,586
    63
    I didnīt ask for "at the same time".
    --> To avoid further confusion: Show your sketch.
    •   AltAdvertisment
  3. #23
    Oct 2014
    19
    841
    They won't need to write to the same bit at any time. For example TXBUSY would only be written by the Tx module.
    •   AltAdvertisment
  4. #24
    Points: 29,649, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,839
    29,649
    41
    Quote Originally Posted by groover View Post
    to it to keep everything in one place.
    I see that for the size of memories, the width of buses, etc. putting values in parameters allows instantiation of different copies of module with different settings, so maybe the number of registers is a special case and can be a parameter, but considering my aim of describing bits in one place how would you recommend I do this without defines?
    Thanks!
    `include my_parameters_of_the_register_definitions.vhd
    and include it in any file that needs to access those address definitions.
    or pass the parameters through the instantiations of all the modules from the top level (my preferred method).
    Using parameters makes code far more portable and reusable.
  5. #25
    Apr 2014
    13,823
    67,586
    63
    This is what I thought.
    It's your job to provide informations...I don't want to ask again...
    •   AltAdvertisment
  6. #26
    Oct 2014
    19
    841
    Quote Originally Posted by ads-ee View Post
    Many thanks for all your help ads-ee! I have decided to go with the trickle-down parameters like you suggested. I already have a basic version implemented.
