Results 1 to 5 of 5
    Junior Member level 3
    Points: 273, Level: 3
    Apr 2018
    25
    273
    Instantiating module with inout
    Hello!
    I am new in verilog and I begin working on I2C protocol hardware implementation
    The master code works well
    but when I combine all files together the master code does not work as it was
    "sda_reg" is the problem and I do not know what I did wrong
    the top code
    module top;
    wire clock,reset,start;
    wire [7:0]addr;
    wire [7:0]data;
    wire [7:0] out;
    wire scl_w ,sda_w ;
    master m1(.clk(clock),.start(start),.reset(reset),.addr(addr),.data(data),.scl(scl_w),.sda(sda_w));
    slave s1(.scl(scl_w),.sda(sda_w),.data(out));
    endmodule
    And "sda" is inout
    This is the piece of code related to "sda" (from master code)
    assign sda = enable? sda_reg : sda;
    Points: 256,119, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,672
    256,119
    100
    Re: Instantiating module with inout
    Code Verilog - [expand]
    Makes no sense. You want to tristate SDA when disabled instead of forming a latch.
    Apr 2018
    25
    273
    Hello, FvM!
    In the first image, "enable" signal was = 1. So sda = sda_reg and that works
    In the second image, "enable" signal was = 1. sda should = sda_reg but this is not happening
    When "enable" =0, the master will read from the slave (acknowledge bit)
    I managed this piece in my code, but I can not see the result because of this don't care in my simulation
    If you want the master code, please inform me and I will edit the post
    Thanks!
    Advanced Member level 3
    Points: 5,173, Level: 17
    Feb 2014
    715
    5,173
    17
    The code for driving the tristate at the output should be in this form:
    assign sda = (sda_low) ? 1'b0 : 1'bz;
    One point of confusion I suspect: when sda is being 'driven' to z it will still 'read' 1 or 0 for the purpose of the rest of your code depending on the pin's actual state.
    Apr 2018
    25
    273
    Thanks to you all for commenting. It works when I write it in that way.
    assign sda = enable? sda_reg : 1'bz;
