kangyunmei
Banned
Hello Everyone,
I wanted to make a circuit which would make my LED's glow as per the music beats.
The circuit pretty much helped me and I was successful. But the problem here is that
My LED are not glowing so bright and I hardly see them on full intensity,.
I used a +12V power supply as the input and TIP31C transistor as shown in the ckt diagram.. I guess an op-amp is needed in order to boost up the power of led.
P.S- the LED's I'm using is a 1meter LED strip (LM3258)
And for the help, I need the best way to add a op-amp without messing up my circuit as I already made it on PCB and really look forward to make this circuit work.
Thank You for your time,
Regards
Regards
