What are the normal tricks to closing time in rc and encounter?
liletian
Full Member level 6
Hi all
WHat are the normal tricks to closing time in rc and encounter? maximum fanout can help. Are there other general ways to do it?
Hi all
closing time in rc is trivial, it either passes or it needs a redesign. people won't even call it timing closure because it really isn't. either you meet specs or go home.
on the physical synthesis side of things, you have to understand what are the sources of issues. clock is not ideal, power distribution is not ideal, coupling hurts you, routing is extracted instead of estimated, etc. there is no one size fits all solution to closure. just tackle one problem at a time. fanout control is really not an issue/solution.
