Results 1 to 5 of 5
    Points: 34,398, Level: 45
    Sep 2008
    cambridge
    7,147
    34,398
    45
    What connects to the termianls of this Philips LED driver
    In the Philips 75W Xitanium SR LED driver, what should be connected in to the SR+ and SR- terminals of the connector? (page 1 of datasheet)
    Is it an external device which needs powering from the SR+ and SR- terminals , or is it an external device which provides a powered DALI bus into the SR+ and SR- terminals?
    Philips SR LED driver:
    https://www.na.mytechnologyportal.li...+datasheet.pdf
    Also, for the following Philips Xitanium LED driver, page 3 of its datasheet shows DALI terminals on its connector. Are these terminals for connecting a powered DALI bus into the product?…….or are these terminals for connecting an unpowered DALI device to the product? (which then receives the powered DALI bus from the product)
    http://www.docs.lighting.philips.com...9000852103.pdf
    Points: 264,406, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,200
    264,406
    100
    Re: What connects to the termianls of this Philips LED driver
    Are we in the LED driver business or is it you? The question is clearly answered in Philips product literature and application notes, e.g. the "Xitanium SR Indoor LED Drivers Design-in Guide". SR stands for "sensor ready", connect DALI sensors like a wireless control receiver without the need of an additional power supply.
    Points: 83,156, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,676
    83,156
    70
    Sensor Ready (SR) is a two wire interface to a wireless connection, typically Zigbee but any can be used, including a full internet connection. Think of it as DALI by wireless.
    Sep 2008
    cambridge
    7,147
    34,398
    45
    Thanks,
    -Page 10 of this…..
    http://www.docs.lighting.philips.com...3-31-jpsv1.pdf
    …states (in as many words), that a DALI_device_needing_power_from_the_LED_driver can be connected to the SR+,SR- terminals of the Philips SR LED drivers.
    The thing is, we also want to know whether or not a DALI_device_that_provides_power_for_the_DALI_bus can also be connected to the SR+,SR- terminals?
    We need to know this because some of our customers want to connect a DALI_device_needing_power_from_the_LED_driver , and some customers want to connect a DALI_device_that_provides_power_for_the_DALI_bus.
    We would like to find a LED driver which allows both these types of DALI device connections. It is extremely difficult to find one like this. Do you know of one?
    We are also not sure whether the following FP series xitanium LED driver can accept a DALI_device_needing_power_from_the_LED_driver , or whether it needs a DALI_device_that_provides_power_for_the_DALI_bus…. .
    Xitanium FP series LED driver:
    http://www.docs.lighting.philips.com...9000962306.pdf
    Design in guide for Xitanium FP series
    http://www.docs.lighting.philips.com...driver_DIG.pdf
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,200
    264,406
    100
    SR Design-In Guide safety precautions advises you to turn the power supply off when SR device is used as a standard DALI driver, achieved by a software tool. Don't know if it's necessary under all conditions.
    Obviously standard DALI LED drivers don't expose a power supply, it's not provided by the standard and would be indicated by additional specification parameters like current capability.
