Results 1 to 6 of 6
    Full Member level 3
    Points: 1,374, Level: 8
    Apr 2017
    174
    1,374
    8
    Tracking 'X' in the gate lavel simulation
    I am trying to fix my design, it works in the ModelSim but doesn't work in the hardware. I ran gate level simulation (with the same test bench) but shortly after starting some debug at the output of the FPGA signals got 'X'. Is there any way to track where and when 'X' appears inside the design? All input data from memory are defined. I have an access to some Mentor's tools (QuestaSim, Precision Synthesis etc).
    Points: 265,300, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,356
    265,300
    100
    Re: Tracking 'X' in the gate lavel simulation
    Did you try Modelsim TraceX function?
    Points: 8,868, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,330
    8,868
    22
    Blog Entries
    The manual way to find out why you see an X propagation is to go back in sim time and track down the FIRST source of X. Then find out the reason as to why that X is happening.
    FPGA enthusiast!
    Full Member level 3
    Apr 2017
    174
    1,374
    8
    Ok, I found a source - a missing statement in a reset block.
    I see in my simulation (waveform preview in Modelsim) that the half of the rising edge is blue and half of it is green. The falling edge is half red and half green (the vertical bar which depicts edge of the digital waveform is red at the top and green at the bottom). How to interpret this result of the simulation? The value of the signal between edges is green (=has got a value).
    This piece of logic is interfaced to the model of the SRAM memory.
    Points: 32,382, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,488
    32,382
    43
    You've been here more than long enough to know that...
    A picture is worth way more than all that verbiage you posted and posting the code along with the picture would likely be much more likely to get an answer.
    Points: 41,018, Level: 49
    Mar 2008
    USA
    6,606
    41,018
    49
    I find the "missing statement in a reset block" kind of creepy.
    Reset should be pin-applied signal and nothing but, else you
    may have a simulation that works and a physical result that
    doesn't, or not consistently.
    The small delay is probably some marched-out initial condition
    (saying that reset wasn't happening as completely as it has
    to).
