Results 1 to 2 of 2
    Member level 4
    Points: 1,664, Level: 9
    Jan 2012
    Kelaniya
    68
    1,664
    9
    Logic Path Activation Probability Depending on Input Data Pattern
    Dear All,
    Suppose that we have a synthesized design consists of many short paths and a critical path. Is there a tool that overviews the activation of each paths and path's activation percentage for a given input data pattern ?
    Thanks in advance
    ranaya
    •   AltAdvertisment
    Points: 7,942, Level: 21
    Apr 2016
    1,670
    7,942
    21
    Re: Logic Path Activation Probability Depending on Input Data Pattern
    Quote Originally Posted by ranaya View Post
    Dear All,
    Thanks in advance
    ranaya
    Yes and no. STA will look at all possible input combinations and find the worst possible timing. However, if needed, you can fix the values of some inputs within the tool and let it run a partial analysis. If you constrain all inputs, then yes, it would only look at one combination.
    Really, I am not Sam.
