Results 1 to 8 of 8
    Member level 5
    Points: 530, Level: 4
    Nov 2018
    82
    530
    DC Amplification using OpAmp
    I have a small signal of -10 mV. I need to amplify it to 4 V which need an amplification factor of 400. I would like to use inverting amplifier whose gain is R2/R1, where R2 is a feedback resistor. I am wondering what is the best practice to get the amplification by a factor of 400.
    1- Use one OpAmp to get gain 400. R1 = 100 , R2 = 40 K.
    2- Use two OpAmp in series. Each with a gain of 20. R1 = 500, R2 = 10 K.
    Points: 75,514, Level: 67
    Apr 2014
    15,307
    75,514
    67
    Re: DC Amplification using OpAmp
    One Opamp. Because itīs DC. A second OPAMP just adds more errors.
    The two OPAMP solution is good for AC, when you get problems with to the gain-bandwidth limit of a single OPAMP.
    your calculation is true if the source resistance is way below 100 Ohms.
    For exact overall gain calculation you need to add the source_resistance to the input_resistance.
    Example:
    If your source resistance is 10 Ohms, then combined with your 100R and 40k this gives just a gain of 40k/(10R + 100R) = 363.
    If you want a gain of 400 then you need to subtract the source resistance from the (ideally) calculated input resistance. 100R - 10R = 90R
    Points: 40,377, Level: 49
    LvW's Avatar
    May 2008
    Germany
    5,784
    40,377
    49
    As an alternative, you have mentioned two inverting opamps in serties. From this, I derive that the sign of the amplification (plus or mins) does not matter, correct?
    In this case, why not use a single non-invering opamp stage?
    The advantage: Because of the very high input resistance the internal resistance of the signal source does not matter at all.
    Points: 7,313, Level: 20
    Dec 2015
    Madrid, Spain
    1,275
    7,313
    20
    Quote Originally Posted by LvW View Post
    What about the biasing of the OP Amp. Non inverting input's resistance should be the same value as the parallel of the feedback resistance and the inverting input's one.
    LvW's Avatar
    May 2008
    Germany
    5,784
    40,377
    49
    Quote Originally Posted by CataM View Post
    I know what you mean - you are concerned about offset correction.
    However, this does not change the high-resistive input for a non-inverting configuration.
    1 Megohm plus 1 kohm gives 1.001 Megohm.
    Member level 5
    Nov 2018
    82
    530
    I am not sure if I understood source resistance. I guess it is the resistance of the source, for example signal generator, right ? Usually the standard signal generator has 50 Ohm output characteristic impedance. Is this what you mean source resistance ?
    Is it true for all OpAmps that the input impedance is high and the output impedance is low ?
  7. #7
    Apr 2014
    15,307
    75,514
    67
    Yes.
    Yes. For the Opamp.
    But not for the circuit. Especially the inverting circuit. It's input resistance is the 100 ohms resistor.
  8. #8
    Points: 18,894, Level: 33
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,647
    18,894
    33
    That's only if the opamp's input bias current is sufficient to generate a significant offset voltage through that parallel resistance value.
    Zapper
    Curmudgeon Elektroniker
