Results 1 to 7 of 7
    Banned
    Points: 277, Level: 3
    Nov 2018
    42
    277
    active crossover and passive crossover
    I am very interested in car modification. Those who have a certain understanding of car audio modification may know the concept of active crossover and passive crossover, but it is not very clear to me. What is the active crossover and passive crossover?
    •   AltAdvertisment
    Points: 69,411, Level: 64
    Apr 2014
    14,176
    69,411
    64
    Re: active crossover and passive crossover
    Please do simple internet research on your own.
    in short (not complete infromation):
    * Active crossover is placed at input of the power amplifier
    * Passive crossover is placed at the output of the power amplifier
    For more information, please
    * first do an internet research on your own
    * elaborate your question
    * give (links to) documents you refer to
    •   AltAdvertisment
    Points: 49,577, Level: 54
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,628
    49,577
    54
    Do you know the function of a two-way speaker crossover network or circuit?
    It passes high frequencies to the tweeter but blocks low frequencies that will damage the fragile tweeter. The crossover also passes low frequencies to the woofer and sometimes blocks high frequencies that cause a woofer to Shriek.
    I have seen and heard many speakers with passive crossovers and also many sound systems with active crossovers and most (the ones designed properly) sound fine.
    Most cheap two-way car speakers use only one capacitor in series with the tweeter to prevent damage and the woofer is allowed to Shriek. Some of them sound fine.
    •   AltAdvertisment
    Banned
    Nov 2018
    42
    277
    I am not very clear about the function of a two-way speaker crossover network or circuit? If the quality of the system equipment is not good enough to play the active crossover, it is a waste of money. Many people use the speakers that are very cheap and not very good as active crossover . The sound is not as good as the same brand of good power amplifiers when the whole set of audio is matched. What do you think? Is that right?
    Banned
    Nov 2018
    42
    277
    The difference between the active crossover [moderator action: removed link] and the passive crossover in the car audio is whether the crossover process is before or after the power amplification, and the crossover is called the active crossover before the power amplification.
    •   AltAdvertisment
    Audioguru's Avatar
    Jan 2008
    8,628
    49,577
    54
    One amplifier can drive a speaker that has a passive crossover but two amplifiers are needed for a two-way (woofer and tweeter) active crossover. The active crossover system produces less distortion.
  7. #7
    Points: 50,381, Level: 54
    Apr 2011
    Minneapolis, Minnesota, USA
    12,393
    50,381
    54
    I saw an article telling the benefits of bi-amping: One amplifier for the bass portion (woofer) and another amplifier for the treble portion (tweeter). Although we like the convenience of having a single amplifier do the entire job, it is not sufficient if its watt rating is equal to the sum of the bi-amped sections. Instead the single amp needs to have 5 or 10 times the power we expect. The reasoning has to do with the way we sum peak decibel levels as compared to the way we sum peak watt levels.
