Results 1 to 6 of 6
    Full Member level 1
    Points: 1,990, Level: 10
    May 2010
    fdsf
    107
    1,990
    10
    comparators - pull up or not ?
    hello
    I ordered LMV358IDR comparators to drive FDN340P transistors like on the following schematic
    https://www.arduino.cc/en/uploads/Ma...-schematic.pdf
    but I find it ackward that there is no pullup resistor, I read many times a comparator needed one
    - does it ?
    - since the comparator appears to be powered by 5V USB, if there is no USB plugged in, is it's output low by default, so the FET is open letting any VIN supply go through ? how can I be sure of this ?
    regards
    •   AltAdvertisment
    Points: 255,118, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,452
    255,118
    100
    Re: comparators - pull up or not ?
    LMV358 are rail-to-rail OPs, not comparators, but can be of course used as comparators as well. The output is push-pull, no pull-ups required or useful.
    The OP can work for the application, but I wonder why you don't use single channel LMV321?
    •   AltAdvertisment
    Points: 73,905, Level: 66
    Apr 2014
    14,991
    73,905
    66
    Most comparators have open_collector or open_drain output, but there are also push-pull output comparators.
    LMV358 is no comparator, it is an OPAMP. OPAMPs usually have push-pull ouput.
    An OPAMP is not the same as a comparator. Select the proper device for your application:
    see this: https://www.edaboard.com/showthread....=1#post1619298
    •   AltAdvertisment
    Full Member level 1
    May 2010
    fdsf
    107
    1,990
    10
    actualy I have 2 usb connectors, one for a teensy , one for an arduino
    they dont have any USB power switching
    and indeed I should have ordered 321
    can you answer my 2nd question too?
    appreciate your help
    it's the official arduino schematic, so I'll reproduce it
    but I was wondering what about no USB power -> no power for the comparator -> what is the state of the FET transistor ?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,452
    255,118
    100
    The comparator is powered by +5V node, derived from Vin and Vusb. In so far I don't understand the question.
    You should pay attention to the MOSFET direction. It's main function is block reverse feeding the USB from VIN. It switches off if Vin > 6.6V, not strictly the expected safe behavior of an USB client according to USB standard.
    •   AltAdvertisment
    Full Member level 1
    May 2010
    fdsf
    107
    1,990
    10
    if USB (through mosfet) and VIN (through VREG) both produce 5V and reach the same 5V point in the schematic
    then a simple diode would do the trick, right ?
