Results 1 to 6 of 6
    Points: 322, Level: 3
    Mar 2018
    36
    322
    Potentiometer with Microcontroller
    If my microcontroller's operating voltage is +3.3V, Is it possible to connect +6V operating potentiometer's wiper pin to microcontroller's ADC input?
    Or Is it possible to use external +6V operating ADC IC with +3.3V operating microcontroller?
    •   AltAdvertisment
    Points: 28,175, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,407
    28,175
    40
    Blog Entries
    Re: Potentiometer with Microcontroller
    Why not use a simple resistive divider along with the potentiometer ?
    Thus you are able to limit the maximum value of the input voltage in the ADC.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   AltAdvertisment
    Full Member level 6
    Points: 1,913, Level: 10
    Aug 2017
    363
    1,913
    10
    No you cannot directly that is through pot feed 6V to a 3.3V MCUs analog input pin because it will damage the ADC module.
    You can use a voltage divider and make necessary conversion in the code. A 2x 5k resistor will divide the voltage into 3V and 3V. So, you can use one 5k resistor at top and a 5k pot at bottom in the voltage divider and connect the POT wiper to ADC input pin.
    •   AltAdvertisment
    Points: 76,079, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,441
    76,079
    67
    .. well, actually you can wire it with 6V at the top of the wiper as long as the voltage from the wiper is never allowed to go higher than the MCU supply voltage. If it goes higher the ADC input will fry.
    The easiest way to prevent it happening is to use a single resistor from the top of the potentiometer to the 6V supply but as you haven't told us what value the potentiometer is, we can't advise on the value to use. To halve the voltage you probably want one with the same resistance as the potentiometer track. For example if you potentiometer is 10K, add a fixed 10K between the track and the 6V line.
    Yes, you can also use an external ADC device that can directly measure 6V but then you have to check you haven't moved the problem to one of logic levels differences between the MCU and ADC.
    Mar 2018
    36
    322
    Thanks for all the replies, I'm going to use MU-615A potentiometer which is 700 (+-200) ohms .
    •   AltAdvertisment
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,441
    76,079
    67
    What is your application Vilfred?
    That value is quite low and if you only want to vary a voltage for measurement it will waste quite a lot of power.
