Results 1 to 6 of 6
    Points: 83, Level: 1
    Nov 2018
    83
    How to open PCB file
    I have to open a .pcb file but I'm not able to do it. I have tried with Altium but it say "File type not recognize". I have tried all the importers with pcb extension on Altium but none of them work.
    I have also tried with Orcad and Cadstar but the result was the same.
    Any idea?
    •   AltAdvertisment
    Points: 78,060, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,773
    78,060
    68
    Re: How to open PCB file
    PADS, Protel and several other programs use .pcb as a file extension. Most store the data as lines of text describing the start and end points of track segments and pad shapes so it you open it in a text editor you might find clues.
    •   AltAdvertisment
    Points: 253,727, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,205
    253,727
    100
    Instead of guessing the dedicated layout tool or trial-and error work, it may be easier to scan the file source (and it's neighborhood) for info about the used tool.
    •   AltAdvertisment
    Nov 2018
    83
    Thanks for replying.
    I already opened the file with notepad but I didn't find any information about the used program.
    I'll try with PADS PCB viewer now.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,205
    253,727
    100
    Yes, some PCB tools use ASCII like format, e.g. newer Eagle files. Your apparently doesn't.
    •   AltAdvertisment
    Nov 2018
    83
    Using Free PADS PCB Viewer I'm able to open these files.
    Actually the problem is that I have to modify them and I just have Altium. How can I import to Altium? Looks like there is no importer for PADS .pcb files
    Thank you so much
    I think that I have to convert it from pcb to ASCII, then I can use the import wizard in Altium.
    The only problem is that I don't have PADS for doing this...
