Results 1 to 6 of 6
    Newbie level 5
    Points: 60, Level: 1
    Nov 2018
    10
    60
    FPGA Module with 12 bit ADC
    Any suggestion on FPGA development board having 12 bit ADC ? the cheaper one !!
    •   AltAdvertisment
    Points: 66,847, Level: 63
    Apr 2014
    13,644
    66,847
    63
    Re: FPGA Module with 12 bit ADC
    If IŽd look for something like this...
    * IŽd give a list of preferred FPGA manufacturers (are you really free to choose any manufacturer and any FPGA of random complexitiy? What about availability?)
    * IŽd give ADC specifications, like voltage range, sampling rate, precision...
    currently on ebay (this link may time out):
    https://www.ebay.com/itm/High-Speed-...tkz:rk:26:pf:0
    Please donŽt contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    •   AltAdvertisment
    Full Member level 3
    Points: 1,058, Level: 7
    Apr 2017
    156
    1,058
    7
    Quote Originally Posted by joniengr View Post
    Look at Cmod A7 with Artix - there is ADC 12bit 1 Msps inside the chip.
    •   AltAdvertisment
    Newbie level 5
    Nov 2018
    10
    60
    Manufacturer: Xilinx
    Analog Signal: 10 KHz signal, 0-3 V
    ADC Sampling: 100 KSPS
    Full Member level 5
    Points: 2,001, Level: 10
    May 2014
    242
    2,001
    10
    I would go with #3.
    Get the artix 7 board, then all your other projects can be build on the use of pmod
    •   AltAdvertisment
    Newbie level 5
    Nov 2018
    10
    60
    Thanks for suggestion. I guess Cmod A7 has USB-UART and USB-JTAG Programming Circuitry bridged on a single micro USB port. Is that right ? but is UART capable to send 100 Kilo Sample Per Second ?
