Results 1 to 3 of 3
    Points: 206, Level: 2
    Nov 2018
    38
    206
    UART transmission rate
    I am sending data from a microcontroller to CPU with baudrate 1200, one start bit and one stop bit. I am trying to figure out how much time is needed to send 30 characters or symbols (e.g, a, b, c, ... etc). Here is some calculation.
    Assumption: Buadrate is bit rate per second and 10 bits are required to send a character.
    Characters per second = 1200 / 10 = 120
    Time required to send 30 characters = ( 1 / 120 ) x 30 = 250 m sec
    Is that right ?
    •   AltAdvertisment
    Points: 68,591, Level: 63
    Apr 2014
    14,003
    68,591
    63
    Re: UART transmission rate
    Correct.
    •   AltAdvertisment
    Points: 28,175, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,406
    28,175
    40
    Blog Entries
    Quote Originally Posted by joniengr View Post
    Although the UART configuration 8N1 has not been explicit above, it is valuable to know that a reduced set of characters and symbols of the ASCII table can be also transmitted with 7 bits, thus performing an increase in the sending rate.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
