Results 1 to 12 of 12
    Full Member level 2
    Points: 2,106, Level: 10
    Aug 2010
    132
    2,106
    10
    Fuse Amperage Determination Circuit
    Hi
    I need to build a 12V circuit which can determine the amperage of various automotive fuses.
    In other words, a circuit which can show at what amperes the fuse blows out.
    Any starting point tips, shall be appreciated.
    Points: 75,514, Level: 67
    Apr 2014
    15,308
    75,514
    67
    Re: Fuse Amperage Determination Circuit
    May the test trip (destroy) the fuse?
    If yes, then build a current source. Slowly increasing current. Detect the trip event. Measure the current at the trip point. With this you may determine the fuse current rating.
    Full Member level 2
    Aug 2010
    132
    2,106
    10
    Thanks for your input.
    The tips, I was expecting were how to measure, hold and display (analog or digital) ampere reading. As soon as the fuse will blow, the amperes will drop to zero immediately.
    Points: 257,313, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,897
    257,313
    100
    O.K., it's clear that the test will destroy the fuse. The actual tripping current will however strongly depend on the current ramp time and be probably 1.5 to 2 times the nominal current. You'll know if you reviewed fuse specifications.
    Full Member level 2
    Aug 2010
    132
    2,106
    10
    Yes.
    What I get is, the slower we ramp the current, the accurate will be the reading.
    But I couldn't get "....tripping current would be 1.5 - 2 times the nominal current"
    Actually, I need to verify the ampere ratings of the trimmed zinc sheets before using them in fuse blade assembling.
    Apr 2014
    15,308
    75,514
    67
    With fuses there is
    * hold current (depends a little on ambient temperature)
    * trip current (depends on time, heat spreading and a little on ambient temperature)
    I donīt think you can directly measure those values on a bare metal sheet and apply for it a finshed fuse.
    All the other metals will spread heat, the plastics will add other "errors".
    This is for quality control?
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,897
    257,313
    100
    Before you understand why, you would want to review fuse datasheets, e.g. the below one. It shows that tripping time for 2*In can be as high as 5 sec.
    https://www.littelfuse.com/~/media/a...lade_fuses.pdf
  8. #8
    Full Member level 2
    Aug 2010
    132
    2,106
    10
    Yes, I want to be sure of the ratings of the pre-trimmed alloy sheets each for the designated fuse ratings.
    Okay, now I got some idea of the holding and the tripping current. But that brings me to a question: Is the rated current same as trip current current?
    As far as my required circuit is concerned, I am thinking of some single-button-push-operation. I just want to be sure that when current ramp is applied at some fixed rate the fuse blows at its rated current. Of course, some tolerance has to be considered in such crude circuit design.
  9. #9
    Apr 2014
    15,308
    75,514
    67
    How do I have to understand this?
    You want to produce fuses but you dont know the specification?
    Did you read any similar fuseīs specification like mentioned by FvM in post#4?
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,897
    257,313
    100
    It isn't, therefore a fuse isn't allowed to blow at its rated current. In case of the automotive blade fuse, it's guaranteed that it won't blow at rated current + 10% before 100 hours. Assuming a reasonable test duration, you'll apply considerably more than rated current to make the fuse blow.
    Time to reconsider.
  11. #11
    Full Member level 2
    Aug 2010
    132
    2,106
    10
    I do have similar specs of some other for my reference. As I mentioned earlier, I want to be sure that the pre-punched alloy sheet which I bought for a specific amperage is actually rated for those amperes.
    So basically, the circuit which I am looking for would be having 2 parts:
    a) a current ramp source which to begin with a push of button
    b) current measurement such that the analog or digital ampere meter retains its readings even when the fuse has blown.
  12. #12
    Points: 9,710, Level: 23
    d123's Avatar
    Jun 2015
    1,717
    9,710
    23
    b) is a sample and hold. I guess that's probably to do with an ADC that has a latching/hold feature that can be triggered when the other end of the "fuse" no longer presents a current/voltage to whatever is used to sample it, be that a current shunt monitor, a comparator, etc.
