Results 1 to 9 of 9
    Member level 3
    Points: 1,199, Level: 7
    Oct 2014
    57
    1,199
    7
    Cadence Virtuoso run different version called version
    In my csh run file. I setenv the Cadence Version 6.1.6.140 but when it starts succefully, I shows version 6.1.6.500.14.
    There are many warning about envSetVal as well. Could anyone tell what happens? Thank you.
    Points: 17,685, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,721
    17,685
    32
    Re: Cadence Virtuoso run different version called version
    Quote Originally Posted by quyleanh View Post
    In my csh run file.
    Who knows contents of your file ?
    Execute followings as Unix Command.
    virtuoso -V
    virtuoso -W
    True subversion of your Virtuoso is "6.1.6.500.14".
    However, your installation directory name of Virtuoso is "6.1.6.140", I think.
    See top of log file of Virtuoso.
    You can confirm Version, Subversion and location of Virtuoso which you launched.
    Simply, invalid environment variables are defined in system "cdsinit" or "cdsenv" or your ".cdsinit" or your ".cdsenv".
    That's all.
    See log file of Virtuoso.
    Member level 3
    Oct 2014
    57
    1,199
    7
    Quote Originally Posted by pancho_hideboo View Post
    virtuoso -V
    virtuoso -W
    My environment is setup by admin person. I can read this file and cd to the directory.
    As you said, here is log
    Hierarchy:       cadence/ic/6.1.6.140/lnx86/tools.lnx86/dfII/
    Sub version:     sub-version  IC6.1.6-64b.500.14  (64-bit addresses)
    So could you tell me what is the reason of the difference here?
    That's all.
    I think when I run Virtuoso 6.1.7, there are some variables which are generated. Then when switching back to 6.1.6, these variables are invalid.
    This is not problem I think.
    Oct 2006
    Real Homeless
    2,721
    17,685
    32
    Surely read and understand following.
    , I think.
    Simply you installed Virtuoso of "6.1.6.500.14" in directory whose name is "6.1.6.140.
    That's all.
    It can never be.
    Virtuoso never generate variables.
    You or someone modified ".cdsinit" or ".cdsenv".
    That's all.
    Generally, you may ignore.
    However startup speed of virtuoso will be slow down due to many warnings.
    Member level 3
    Oct 2014
    57
    1,199
    7
    That's all.
    It can never be.
    That's all.
    I copy the running file, .cdsinit file from my senior. I thought the virtuoso version should be the same but it's not. I don't know why there is different. Could you give some guess for this situation? Thank you.
    Oct 2006
    Real Homeless
    2,721
    17,685
    32
    Simply you or your senior modified ".cdsinit" or/and ".cdsenv".
    That's all.
    Show me followings.
    (1) Sub-Version of your Virtuoso
    (2) Sub-Version of your senior's Virtuoso
    (3) Your .cdsinit
    (4) Your .cdsenv
    (5) Log file of your Virtuoso
  7. #7
    Member level 3
    Oct 2014
    57
    1,199
    7
    That's all.
    I think the .cdsenv file. Because the .cdsinit I copied from him.
    Show me followings.
    (3) Your .cdsinit
    (4) Your .cdsenv
    1. I've already posted.
    2. I cannot see the content because he in the different host.
    3. Only this matters
     when( isFile("~/.cdsinit") load("~/.cdsinit"))
    Other things about simulation and calibre setup.
    There is no .cdsinit file in ~/ foler.
    4. 5. Because the sensitive contents, I cannot post here. Could you tell me the specific parts which you want to see?
  8. #8
    Oct 2006
    Real Homeless
    2,721
    17,685
    32
    This is contradictory to the following.
    Where do you copy ".cdsinit" ?
    Is there "~/.cdsenv" ?
    I cannot post here.
    Close this thread since you don't show your true information.
    Your issues are very easy and trifling.
    Resolve by yourself.
  9. #9
    Member level 3
    Oct 2014
    57
    1,199
    7
    I copy the .cdsinit file from my senior working folder. I can access to his working folder (because his and mine are the same directory), but I cannot access to his home folder (~/). Please take a look at this command.
    cp working_directory/mysenior/.cdsinit working_directory/me/
    There is "~/.cdsenv", but there is NOT "~/.cdsinit" file.
    Thank you for your patience and kind help. As I said, I cannot provide FULL file and I just want to hear the guess and suggestion. I do know a bit about cadence configurations but I don't know what is problem in this case, so I ask.
