Results 1 to 4 of 4
    Newbie level 3
    Points: 235, Level: 2
    Sep 2017
    235
    Cadence Spectre cannot read library model files
    Hello everyone,
    Recently I am using Cadence Spectre Version 16.1.0 to simulate a netlist in command line. However, I met the error when reading the library model file:
    Reading file: /home/grads/z/zhanxin/PowerDeliveryNetwork/IBM_90nm_models/IBM_PDK/cmos9sf/V2.2.0.1IBM/Spectre/models/design.scs
    Fatal error found by spectre during circuit read-in.
    FATAL (SFE-867): Unable to open the file `/home/grads/z/zhanxin/PowerDeliveryNetwork/IBM_90nm_models/IBM_PDK/cmos9sf/V2.2.0.1IBM/Spectre/models/design.scs'.
    That circuit library file (design.scs) could be accessed via vim, so this excludes the possibility of path error. Is there anyone having experiences about how to solve it?
    Thanks a lot!
    Xin
    Points: 17,690, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,724
    17,690
    32
    Re: Cadence Spectre cannot read library model files
    Quote Originally Posted by zhanxin319 View Post
    Don't you run Spectre as distributed process ?
    Confirm file permission.
    Is it "rw-r--r--" or "r--r--r--" ?
    Points: 31,084, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,564
    31,084
    43
    The file format could be broken due to editor. Because some text editors may add some extra hidden characters into file and Cadence Spectre sees those characters even they are not visible.
    I lived a problem with a model card file once due to a small "point". Check this out..
    Newbie level 3
    Sep 2017
    235
    It seems that the 32-bit Spectre was started by default, which cause a file loading issue on a 64-bit machine. It is fixed by adding '-64' option.. Thank you guys anyway..
