Results 1 to 8 of 8
    Junior Member level 2
    Points: 487, Level: 4
    Jan 2017
    20
    487
    Mathematical formula of the minimum separations required between two patch antennas?
    please i want to know the D (maximum dimension of antenna) given in this equation is the width * length of the patch antenna or not?Click image for larger version.
    Points: 6,699, Level: 19
    Jun 2012
    Edmonton, Canada
    1,030
    6,699
    19
    Re: Mathematical formula of the minimum separations required between two patch antenn
    Hi Suo,
    This looks like the equation for the far-field distance of an antenna; in that case D is typically taken to be the diameter of the smallest possible sphere that encloses your antenna.
    Jan 2017
    20
    487
    so do you know the mathematical formula between the distance between element patch antennas and dimentions of antennas?
    Points: 51,990, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,753
    51,990
    55
    I have a weather forecast system (WeatherDirect) that receives information over the internet. The three units talk by rf communication. The instructions advise me not to place them close together.
    In fact they state in the event one unit doesn't recognize the other, then I should increase their separation as much as several feet. I suppose multipath is the issue here. Perhaps it is most problematic when reflective objects are close to both transmitter and receiver.
    Points: 33,639, Level: 44
    Oct 2001
    4,804
    33,639
    44
    Quote Originally Posted by Suo View Post
    In the far-field equation, D is the largest dimension of the antenna.
    In case of a patch antenna, D will be equal to which one is bigger, from L length or W width.
    Jan 2017
    20
    487
    Hello vfone,
    what do you mean please?
    you mean that when the length is bigger than the width of rectangular patch antenna, then D is the length and vice versa?
    i need your answer please.
  7. #7
    Oct 2001
    4,804
    33,639
    44
    Yes, exactly.
    In patch antenna design generally the width W is larger than the length L, but there are applications (some array antennas) where is in the other way.
  8. #8
    Full Member level 2
    Points: 1,011, Level: 7
    Oct 2017
    140
    1,011
    7
    What is "wavelength of lower cutoff frequency"? Cutoff frequency of array?
    Does this imply the following:
    For narrow-band antennas lambda=1 D=0.5 and dmin=2*d^2/lambda=0.5
    Then for wide-band antennas separation must be bigger. as lambda is fraction of 1?
