[SOLVED] VHDL Aliases advanced usecase of name signment
wtr
Full Member level 5
Hello all,
We've got a board where the test_leds have been routed terribly.
TEST_LEDS(9 downto 0) are wired in a scattered format
Looks something like this
(3)--------(8)
(8)--------(5)
(4)--------(2)
(9)--------(1)
(0)--------(7)
I want to be able to generate an alias name that can be assigned using slicing.
The following is the alias syntax rule
alias_declaration ::=
alias alias_designator [ : subtype_indication ] is name [ signature ] ;
alias_designator ::= identifier | character_literal | operator_symbol
Code VHDL - [expand]
alias led : std_logic_vector(TEST_LEDS'range) is xxx
Where I want xxx to be test_led(0) & test_led(9) etc
I know the following works but it doesn't give me the std_logic_vector I want for slicing.
alias led9 : std_logic is test_led(0);
alias led8 : std_logic is test_led(9);
For this, you'd probably be better off just creating a slv signal and assigning the leds in a more suitable order. You can only alias to existing objects.
I would either have a permutation function, do the permutation elsewhere at the top level, or do the permutation in the xdc file.
So,
The following is allowed because TEST_LEDS object exists, even if we've switched range ascending/deceasing and sliced it.
alias leds : std_logic_vector(3 downto 0) is TEST_LEDS(3 downto 0);
alias leds2 : std_logic_vector(3 downto 0) is TEST_LEDS(4 to 7);
However one cannot create a """new""" object by concatenating a selection of objects?
alias leds : std_logic_vector(7 downto 0) is TEST_LEDS(4 to 7) & TEST_LEDS(3 downto 0);
An object is (a constant, variable signal or a file) <- basically stuff before the begin keyboard in architecture body.
This is a shame.
Was aware of the slv method, but was trying to do something clever/pushing the language.
why not just create another signal? It really isnt any different to what you're doing.
TrickyDicky,
It's not about getting to the destination. IT's about the journey.
Sometimes, during the journey, an npc suggests adding a layer of indirection. Upon completing this quest you gain +1 wisdom.
Reactions: wtr
    wtr
