Results 1 to 2 of 2
    Newbie level 1
    Points: 15, Level: 1
    Nov 2018
    15
    computer related hardware section problem
    Respected sir/mam,
    Recently i hv problem in my pc that after putting on & it is shuting down sometimes within half an hour or more ? ihv changed smps,then also not solved,so what could be the problem, is it related with motherboard,or operating system orany other issues?
    kindly help me for above said problem would appreciable.
    Thanking you.
    Regds
    jay1
    Points: 79,829, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,066
    79,829
    68
    Re: computer related hardware section problem
    Could be many things, including he software you have installed or BIOS settings but usually if it happens after a certain time it is heat related. The temperature gradually increasing after switch on until it causes failure. Check cooling fans are operting and free to turn and all the ventilation openings are clear. Also check for dust building up on the CPU heatsink which may not be obvious when looking through the fan.
