Results 1 to 4 of 4
    Member level 3
    Points: 641, Level: 5
    Feb 2017
    64
    641
    Error Response from server whensending POST request using sim800
    I want to send data to a server using POST method with sim800. When I use POSTMAN, data is sent correctly but when I use the same headers of POSTMAN in the sim800 error is returend from the server and below message is recieved:
    HTTP/1.1 200 OK
    Server: nginx/1.14.0 (Ubuntu)
    Date: Thu, 01 Nov 2018 21:48:40 GMT
    Content-Type: text/html; charset=utf-8
    Content-Length: 5
    Connection: keep-alive
    Error
    CLOSED
    what can be the problem?! I use the below AT commands sequence in sim800:
    AT+CGATT=1
    AT+CIPMUX=0
    AT+CSTT="APN","USER","PASS"
    AT+CIICR
    AT+CIFSR
    AT+CIPSHUT
    AT+CIPSEND=20
    POST /post HTTP/1.1
    Host: **.**.***.***
    Content-Type: application/json
    Content-Length:23
    {"postkey":"postvalue"}
    •   AltAdvertisment
    Junior Member level 1
    Points: 126, Level: 1
    AskSensors's Avatar
    Oct 2018
    Paris
    18
    126
    Re: Error Response from server whensending POST request using sim800
    I see the answer of 200 HTTP code (means request received OK).
    But after, it seems that something happens with your nginx server.
    Have you tried to send requests to another server instead. just to verify that your code with SIM8080 works well with other servers.
    •   AltAdvertisment
    Member level 3
    Feb 2017
    64
    641
    Quote Originally Posted by AskSensors View Post
    I found that the problem was from the server side that returned error response.
    •   AltAdvertisment
    Points: 1,858, Level: 10
    Jan 2009
    15
    1,858
    10
    Re: Error response from server when sending a POST request using SIM800
