Results 1 to 10 of 10
    Points: 30,735, Level: 42
    Sep 2008
    cambridge
    6,423
    30,735
    42
    3 Watt inrush resistor will eventually fail?
    We have designed a 60W offline (190-265VAC) Flyback LED driver (PFC’d). We have a 4R7, 3W inrush resistor near the mains input connector. (as in the attached schematic)
    This is a 3W axial film resistor , type “ROX3S”
    ROX3S resistor datasheet…
    https://www.te.com/commerce/Document...ocLang=English
    Do you think this resistor will eventually fail after a number of ON cycles, especially with some of them happening at the instant of mains peak voltage?
    Points: 75,009, Level: 66
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,294
    75,009
    66
    Re: 3 Watt inrush resistor will eventually fail?
    I would guess, without going into complex calculations that it would be fine. The 3W rating is for continuous running which would equate to the lamp drawing about 800mA (~180W load) and the resistor is built to handle high surge currents. The surge would be brief and you already have a further current limiter after it. You only have about 5uF of capacitance to charge up.
    •   AltAdvertisment
    Points: 15,058, Level: 29
    Nov 2012
    2,786
    15,058
    29
    Resistors are robust beasts. If the rating is 3W nominal, it can survive 30W peak for several ms. (just guessing).
    Fortunately, unlike semiconductor damages, resistor damages are not cumulative. The beast can heal with time (only partly but then...).
    Film resistors are particularly strong but then I do not know the exact details.
    •   AltAdvertisment
    Member level 3
    Points: 1,909, Level: 10
    thunderdantheman's Avatar
    Jan 2010
    Australia
    60
    1,909
    10
    What you want to look for is the pulse rating of the resistor.. Or if not specified for your current part, consider using a pulse-rated resistors.. these are designed and specified (among other things) for exactly what you are trying to achieve. This appears informative on the subject https://aerospacepal.com/resistor-pu...ing-explained/
    •   AltAdvertisment
    Nov 2012
    2,786
    15,058
    29
    It may be not worth the trouble: a fast-acting fuse designed to protect an expensive transistor, was itself protected by the transistor getting blown up in a surge.
    Member level 3
    Points: 1,867, Level: 10
    Nik_2213's Avatar
    Jul 2010
    UK
    65
    1,867
    10
    What was the type of inrush catcher used on BIG linear power supplies ?
    The sort of PSU with a pair of thousand-plus micro-Farad 'beer cans' ??
    Plus a 'bleed resistor', lest their residual polarisation bites the unwary ?
    I remember them as bespoke NTC devices, but such were out of my league...
  7. #7
    Full Member level 4
    Points: 1,617, Level: 9
    Relayer's Avatar
    Jul 2016
    Werribee, Australia
    204
    1,617
    9
    Hello treez,
    4.7 ohm 3 and 5 watt resistors have been in use with virtually every bit of consumer
    appliances over the years, and in those, it was extremely rare that it ever failed on its own.
    Its main failure was due to excessive current from a shorted bridge rectifier diode/s or
    chopper transistor, where the fuse took too long to blow.
    In some instances when the degaussing thermistor goes S/C it can take it out as well.
    If you were using a NTC thermistor to suppress inrush currents and spikes, that would be a different
    story. The chemical composition of those devices changes over time and never seem to recover to
    their normal state. They then eventually suppress less and less and allow more inrush current, to the
    point of virtually becoming shorted and no longer do squat. Therefore they will fail after many years
    with fairly violent consequences.
    i.e. Taking quite a bit of other components with them.
    Regards,
    Relayer
    •   AltAdvertisment
  8. #8
    Full Member level 2
    Points: 1,509, Level: 8
    Jan 2015
    Shrewsbury, Shropshire, UK
    133
    1,509
    8
    When I design something like this it's worth noting what the resistor's energy rating is as that is more relevant. You see a direct reflection of the Capacitor energy when you charge it. Saying that I have used NTC thermistors as other correspondents have pointed out.
    Regards,
    Rob.
    Please don't send me PMs asking for direct help as this somewhat defeats the object of posting to a board like this.
    Any posts are simply an opinion and are not to be taken as professional advice. You are responsible for your own actions.
  9. #9
    Advanced Member level 2
    Points: 4,066, Level: 15
    Feb 2014
    525
    4,066
    15
    Yes you should find the joule rating of the device or use the pulse rating chart to extract one. Then compare to the energy in your cap.
    A small subset of resistors have a proper joule rating. Other manufactures have app notes covering it generally.
    An NTC would probably be superior for a non-bypassed inrush limiter. A PTC can be ideal for a bypassed application.
  10. #10
    Nov 2012
    2,786
    15,058
    29
    Most semiconductor device failures follow a Poisson distribution and is associated with a quantity "mean life expectancy". A design is robust when all the components used in the design have similar life expectancy at the beginning.
    In your present application, the mean life expectancy is related to the related to the number of turn on/off events. You therefore need to estimate the mean number of turn on/off the resistor can stand. Poisson distribution is exponential in nature and the device can also fail before and after.
    Perhaps some other component (perhaps a transistor used as a switch) may have a shorter expected life? In such a case, it is not worth worrying too much about a resistor. It may survive the life of the lamp...
