T
treez
Page 31 of AN5 by power.com states that a good way to reduce conducted emissions in an offline SMPS
that is in a plastic enclosure is to put a metal plate under the enclosure...
this metal plate being the same size as the power supply PCB. It says that this plate should be
connected to the incoming Earth ground.
I would have thought that this procedure would result in worse common mode emissions?
Page 29 of AN15 states that we can view only the common mode conducted emissions of an offline SMPS by
use of two splitters (an in -phase splitter, and an out-of-phase splitter). Does anyone have such a conducted emissions
scan available to share here? (ie a conducted scan of an offline smps with the splitters attached)
Page 3 of AN15 shows a conducted EMC emissions setup for an offline SMPS (figure 6). It says that 6 foot cables
should be used between the unit under test and the LISN, and the UUT and the load....but in the picture they
dont look like 6 foot cables, they look much shorter...can this be "six foot" be right?
Also, it seems to be saying that the table is up against a vertical "reference plane" which is 2m by 2m. Presumably this
reference plane is just a floating piece of metal sheet? The LISN must be bonded to this metal plane. I thought that the LISN
should be right up against the reference plane, so that the LISN's connection to the reference plane can be as short as possible?
Also, i thought that the table should have a metal sheet beneath it aswell as the one at the end of it?
Also, where does the spectrum analyser go in this setup?..presumably it connects to the LISN via a coaxial cable..and the specturm analyser is
at least 2 metres away from the unit under test?
Also, since the test setup in figure 6 is not as complete as in an accredited test house, the conducted EMC scans will be discrepant.
What will be the main nature of this discrepancy?
AN15
https://ac-dc.power.com/design-supp...on-notes/an-15-topswitch-power-supply-design/
AN15
