Laplace from a frequency dependent expression
franticEB
Full Member level 3
laplace from frequency dependant expression
Hi, i have this expression representing a frequency dependant power loss:
a=0.6265
b=2.24
c=1.41
Bpk=0.3 Kgauss
f=frequency
Ploss=a*Bpk^b*f^c
is it possible to obtain a laplace transform of Ploss (transfer function of s)?
Let me know
Re: laplace from frequency dependant expression
Laplace transforms are for linear functions. Your exponential function is not linear.
Ratch
As long as your function meets Dirichlet conditions and is majorized by an exponential function, it has a Laplace transform.
However, usually we are transforming time-domain functions to s-domain (which is a generalization of frequency to a complex surface), so frankly speaking I don't understand why you would like to transform frequency-dependent function into s-domain. Especially, while supposing the time domain primary function has a right-sided complex Fourier representation, and this representation is in fact your function, the s-domain representation would be the same with s instead of f.
What would be the physical meaning of Laplace transform of frequency-dependent power loss function?
You didn't observe the hint by Ratch. The magnitude term B^c is nonlinear and has no inverse Laplace transformation, except for the trivial case c=1. Even then I don't see a particular physical meaning.
