Results 1 to 5 of 5
    Newbie level 5
    Points: 688, Level: 5
    Apr 2015
    9
    688
    CPU of Video Player halts when with LVDS
    Hello everyone
    I have designed a PCB which plays videos and shows pictures from USB flash.
    Output videos are 3 which are a 50-pin FPC connector, a 60-pin FPC connector and a LVDS output (2*10 pin header).
    when I connect FPC connectors to the board output, everything works properly. sound is good and video is fine as well.
    But when I receive my video output from LVDS connector, It works for almost 7 or 8 hours and then CPU halts and video gets disrupted.
    I have attached two pictures of my PCB
    The link to the pictures
    https://imgur.com/a/PLvMFss
    any help would be greatly appreciated.
    best regards
    Points: 22,506, Level: 36
    barry's Avatar
    Mar 2005
    California, USA
    4,301
    22,506
    36
    Re: CPU of Video Player halts when with LVDS
    The problem is obviously that one layer is red and the other is blue.
    How do you expect anyone to solve your problem by looking at a picture of your pcb? If I sent you a picture of my car, do you think you could diagnose the engine problem????
    But seriously, your problem is probably heat related.
    Newbie level 5
    Apr 2015
    9
    688
    Quote Originally Posted by barry View Post
    If It's problem related then it should be solved when I put a heatsink on CPU which I do but it halts anyway.
    Not to mention CPU doesn't get hot when I use heatsink.
    barry's Avatar
    Mar 2005
    California, USA
    4,301
    22,506
    36
    How do you know your CPU halted? Have you looked at signals with a scope? Reset? Clock? I assume there are more components on your board than a CPU; maybe one of THEM overheats? Maybe you've got a timing issue; those type of things may take hours to show up. Maybe you're getting a static surge. Or a power line glitch.
    I can sit here all day and make wild guesses, but you need to do more digging.
    Points: 29,848, Level: 42
    ads-ee's Avatar
    Sep 2013
    USA
    6,874
    29,848
    42
    Another possibility is a buffer over/under flow problem, those usually show up after you run stuff like this for extended periods of time.
