Results 1 to 4 of 4
    Newbie level 5
    Points: 169, Level: 2
    Apr 2018
    9
    169
    802.11 a and 802.11af
    In the implementation of the standards, does it take them to have different devices or do they use the same? Only that they differ in the frequency of opration and bandwidth. Thanks in advance.
    Points: 256,712, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,784
    256,712
    100
    Re: 802.11 a and 802.11af
    I'm not aware of retail products implementing 802.11af. Unless you can correct me, the question is purely hypothetical. Technically, it's feasible to make combo devices supporting 2.4/5 GHz bands and new UHF WiFi bands.
    Newbie level 5
    Apr 2018
    9
    169
    Im trying to simulate this standard in matlab. 802.11a is already available. Do you think that 802.11af modification is possible from 802.11a preimplemented software?
    Full Member level 4
    Points: 2,220, Level: 10
    Created Blog entry
    Oct 2013
    Sweden
    205
    2,220
    10
    Blog Entries
    Overall, they are very different and are targeted towards different devices. (For comparison, it is worth noting that 802.11a is virtually identical to 802.11g - they just operate in different frequency bands).
    However, deep down in the structures of 802.11a and 802.11af, they do use some similar techniques. In particular, both use OFDM QAM. However, the schemes used by 802.11af are more specifically based on 802.11ac (which is 2 generations newer than 802.11a/g and has numerous new features. The release order was 802.11a/g --> 802.11n --> 802.11ac).
    If you want any help simulating 802.11a/g, I highly recommend working through Annex I.1 of the standard. I recently uploaded all of my MATLAB code for doing that here: https://www.edaboard.com/entry.php?2069.
    802.11ac (and therefore 802.11af) is massively more complex. I would therefore recommend starting simple and only trying to tackle a small subset of the possible features. Do you want to simulate demodulation, or only modulation? (Demodulation is much, much more complex than modulation. I intend to upload some code for that soon.).
