Results 1 to 10 of 10
    Member level 3
    Points: 489, Level: 4
    Aug 2018
    61
    489
    Modbus Communication circuit
    I am trying to communicate modbus communication with PIC16F886/pic18F24k40/pic16F1938.I tested my code with MAX482 AND SN75176A NON isolated version of IC and its working fine . Now i am testing same code with DE controlled using ADM 2483 .In Non isolated version i could not able to communicate.Is there any proven circuit or IC where it has been tested with above controller in Isolated version.
    I have attached my schmatic for reference,
    http://love2007.spaces.eepw.com.cn/a...le/item/100739
Name:	Rs485 circuit.JPG
    This circuit i have tested with DISPIC33FJ128GP706(Which is operated 3V3) But not working with PIC16F1938 or similar. I have used pull up resistor 10K instead of 4.7k/4.5k resistor .It didnt worked. I wont get proper request from slave device itself. kindly suggested any proven circuit with above ic.
    Points: 80,159, Level: 69
    Apr 2014
    16,262
    80,159
    69
    Re: Modbus Communication circuit
    use a scope and show the signals.
    Member level 5
    Points: 1,855, Level: 10
    May 2012
    Maryland, USA
    83
    1,855
    10
    Are you providing the Common connection on the isolated bus side? That would be the GND2 in your schematic. On the non-isolated version you are likely picking it through other means. When you try the isolated version, if that's not there you have no common mode reference point.
    Member level 3
    Aug 2018
    61
    489
Name:	Before_Connecting ADM2483.jpg
Name:	After_ADM2483 connected.jpg
    Here I have attached Both Waveform Connected before and after connecting ADM2483 circuit.
    In Before circuit i used USB to TTl converter. I am sending Modbus request through modscan32 software where i am getting response.
    Now Usb to TTl converter replaced with USB to RS485 device with TX and Rx line tapped. When i tried to response.I wont get Request from System as shown in figure. With some of resistor pull of network i used to get request in waveform.
    Kindly suggest me What i need to do solve issue.Thats reason I am asking for right comibniation of circuit.
    Attached circuit is already tested with DISPIC33FJ128GP706 meant for 3V3. I created same waveform to achieve this but still not working.
    Apr 2014
    16,262
    80,159
    69
    To me it seems the DE signal is wrong in timing.
    I don't expect it to change state during any communication.
    Member level 3
    Aug 2018
    61
    489
    How can Adjust the DE Timing.I am enabling when Receive 8 byte of data and disabling while trasnmit data is completed.
    Do you think is there problem with Hardware or software? DE pin will be high when transmit flag complete refer figure before_ADM2483 connected.
    What might be possible reason It wont meet DE signal timing.In case of DSPIC it working. Based on those timing i created these waveform
  7. #7
    Apr 2014
    16,262
    80,159
    69
    I'm not familiar with PIC.
    With other microcontrollers you have multiple flags.
    * one that shows that you may write new data to the buffer (don't use this flag for DE)
    * and the other flag that really shows that all bits has been shifted out (use this flag)
    You need to read the datasheet.
  8. #8
    Member level 3
    Aug 2018
    61
    489
    Here is my code.
    I could not able to get below points can you elaborate. For DE i used DigitalPort to trigger it on and off.
    I am enabling only when 8 byte of data received.
    Or I need to enable DE first then receive 8bit data and then do transmission
    void Serial_Interrupt()
        if((PIE1bits.RCIE==1)&&(PIR1bits.RCIF=1))
    		//PIR1bits.RCIF=0;
            for(index=0; index<8; index++) {
    			rxbuf[index] = Serial_Receive_byte();
           __delay_ms(40);
    		if(index>=8) {
    			rec_flag = 1;
    		if(index>=20)
                DE=1;
    			index=0;
    		if(1==RCSTAbits.FERR)
    			RCSTAbits.SPEN=0;
    			RCSTAbits.SPEN=1;
                // DE=1;
    		if(1==RCSTAbits.OERR)
    			RCSTAbits.CREN=0;
    			RCSTAbits.CREN=1;
                // DE=1;
         CLRWDT();
    void UART_Transmit()
    	if( PIR1bits.TMR2IF ==1)
    		PIR1bits.TMR2IF = 0;
            Disp_count=Disp_count+1;
            Serial_Interrupt();
            if(DE=1)
                   serial_access();
  9. #9
    Apr 2014
    16,262
    80,159
    69
    DE means "driver enable" you need to activate it to send (transmit) data.
    It should not be controlled by the serial receiver.
    Activate DE just before you send out data,
    Deactivate DE when all data bits including STOP bit has finished to send out.
  10. #10
    Member level 3
    Aug 2018
    61
    489
    Thanks for support . Yes its problem with Code . As said i have done code modification. once data being received i adjusted the timing for DE line.
    Then it started working normally.
    I am facing weird while testing it.
    I have 3 Software to make it confirm its working on all software
    1) modscan32
    2) modtester
    3)modbusview
    When i tested with modscan32 & modbus view i used to get proper response with no pole mismatch. If i testing with modtester i got error for illegal response. Is there any possible reason for this
