Results 1 to 7 of 7
11th October 2018, 23:28 #1
Nostalgia thread, did you work with Selenium rectifiers?
My first electronic project that worked, a small audio amplifier, I used a scavenged selenium rectifier.
I also repaired a couple of radios that used them.
On one instance, one blew up and the smoke was nasty.
I later learned that these rectifiers were highly poisonous.
Did you ever came across one?My batteries are recharged by "Helpful Post" ratings.
Advertisment
12th October 2018, 02:45 #2
- Join Date
- Mar 2008
- Location
- USA
- Posts
- 6,172
- Helped
- 1789 / 1789
- Points
- 38,166
- Level
- 47
Re: Nostalgia thread, did you work with Selenium rectifiers?
I found one in an older ('70s) dirt bike as the main (only) rectifier.
Had some in junk boxes which were cool to look at, but not
any more useful than other diodes.
Advertisment
12th October 2018, 08:45 #3
- Join Date
- Jul 2009
- Location
- Aberdyfi, West Wales, UK
- Posts
- 12,530
- Helped
- 4177 / 4177
- Points
- 76,611
- Level
- 67
Selenium certainly stinks when it burns!
I used them back to around the mid 1960's, both as power rectifiers (remember the square blocks with lots of fins?) and small signal diodes. I probably still have a few lying around in the cobwebs.
Brian.PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
Advertisment
12th October 2018, 08:57 #4
- Join Date
- Nov 2012
- Posts
- 2,844
- Helped
- 673 / 673
- Points
- 15,446
- Level
- 29
But the rectifier was the most mysterious device in the whole set.
Selenium is toxic but not highly poisonous. It is needed in trace amounts for both plants and animals. I think the rectifying element is CdSe (but I am not so sure now) and cadmium is far more toxic. H2Se really stinks (but SeO2 is far less offensive).
12th October 2018, 13:44 #5
If I remember correctly, they had forward voltage drops of several volts.
But compared to vacuum tubes, which had a voltage drop of tens of volts, they were an improvement.
I would love to have my hands on one, to see what the V-I curve looks like.My batteries are recharged by "Helpful Post" ratings.
Advertisment
12th October 2018, 16:32 #6
- Join Date
- Jan 2008
- Location
- Bochum, Germany
- Posts
- 43,770
- Helped
- 13308 / 13308
- Points
- 251,342
- Level
- 100
12th October 2018, 17:10 #7
- Join Date
- Jul 2009
- Location
- Posts
- 12,530
- Helped
- 4177 / 4177
- Points
- 76,611
- Level
- 67
I think the last common usage of them was in HV voltage multipliers in early color TV. Inside the "tripler" there would typically be several capacitors and five 'sticks' about 50mm long. Inside each stick was a stack of selenium discs (~50) and a small spring to keep them under compression.
Please login
