Results 1 to 4 of 4
11th October 2018, 21:41 #1
- Join Date
- Oct 2018
- Posts
- 1
- Helped
- 0 / 0
- Points
- 19
- Level
- 1
Advertisment
14th October 2018, 21:47 #2
- Join Date
- Jun 2013
- Location
- Norway
- Posts
- 697
- Helped
- 290 / 290
- Points
- 5,262
- Level
- 17
Re: What are these two circuits?
These two circuits are an ultra high swing current sources (on the first schematic is lack of biasing branch for VBN and VCN so it hard to call it as mirror).
The first one was presented first time (as my best knowledge is) at 2002 in the IET Electronics Letters (don't remember details), while second was published in Elsevier Microelectronics Journal ca 2011.
The first one using only negative feedback (there is double boosting applied) to achieve the most flat output characteristic with output resistance in range of K_1×K_2×K_4×r_3 (where K is an intrinsic gain of each mosfet) and can have very low Vout_min (my experience is as low as 25mV, however it is set by biasing circuit). Due to high gain feedback it would required compensation at gate of M1.
The second circuit has using both negative and positive feedback loop (M3→M1→M2→M4 which are moving minimum Vout to lower values), and now I have seen this circuit is not a mentioned by me UHS CM from MJ_2011. It doesn't has a 3 MOSFETs for negative feedback boosting an output resistance. If you could share with more info where did you found the second scheme, it would be useful to discuss.
Advertisment
17th October 2018, 00:16 #3
- Join Date
- Jul 2016
- Posts
- 182
- Helped
- 2 / 2
- Points
- 1,257
- Level
- 8
How does the second has.negstive feedback? Can't see it/follow. Can you explain please.
Advertisment
17th October 2018, 20:20 #4
- Join Date
- Jun 2013
- Location
- Norway
- Posts
- 697
- Helped
- 290 / 290
- Points
- 5,262
- Level
- 17
I didn't look closely to the second scheme and I was misled by my mind, what I have noticed during writing the post
The circuit which I had on mind is published here:
https://www.sciencedirect.com/scienc...26269210002326
And it contains a three more mosfets (current source output transistor and CS amplifier) composing mentioned by me negative feedback.
The scheme on post #1 has not negative feedback obviously. My mistake.
Please login
