Results 1 to 3 of 3
    Full Member level 4
    Points: 1,348, Level: 8
    Apr 2017
    220
    1,348
    8
    Layout of Switched Capacitor Differential/Single Ended Opamp
    Want to layout a Switched Capacitor Differential/Single Ended Opamp for Data Converters.
    Looking for resources on layout methodology, styles and guidance - also examples.
    What are good books as resources for this topic ?
    Any resources available - books, papers, screenshots etc ? Hopefully 0.18um CMOS and below.
    Thank you.
    •   AltAdvertisment
    Points: 51,484, Level: 55
    erikl's Avatar
    Sep 2008
    Germany
    8,064
    51,484
    55
    Re: Layout of Switched Capacitor Differential/Single Ended Opamp
    Hello Puppet,
    here is a description for such a structure made in a 0.18µm process. For some sub-parts (switch & cap array) there are layouts shown:
    Uni-KL_ADC-review_jan03.pdf
    Here's one more paper about an S/C OpAmp, which might be interesting: Switched_OpAmp_based_10b_integrated_ADC_for_Ultra_Low_Power_Applications.pdf
    Perhaps also check the named references.
    •   AltAdvertisment
    Full Member level 4
    Apr 2017
    220
    1,348
    8
    Erikl,
    Thank you.
    Analog MOS Integrated Circuits for Signal Processing by Temes has some good information on layout for switched capacitor systems even though it is dated.
    If you have any more references like those in the first paper, that would be great.
    Thank you again.
