Results 1 to 3 of 3
    Newbie level 1
    Points: 15, Level: 1
    Oct 2018
    15
    Unable to draw the correct unit cell in CST using AutoCAD
    Dear All, I am currently doing a project that requires me to use both CST and AutoCAD. Please refer to the screen shots below for the models that I have drawn in AutoCAD before exporting it to CST. The entire patch is solid which is not what I want. What I need is a gap in between the patch and the outer ring as shown in the picture below. I am unable to edit the structure in CST. Please advice on what I should do on the AutoCAD side to correct the error. Thank you
ID:	149480Click image for larger version.
ID:	149481Click image for larger version.
    •   AltAdvertisment
    Member level 5
    Points: 3,595, Level: 14
    sassyboy's Avatar
    Sep 2003
    United Kingdom
    94
    3,595
    14
    Re: Unable to draw the correct unit cell in CST using AutoCAD
    Have you tried using Boolean operation to subtract from the square with L1 sides? I find CST workspace is quite easy to draft the unit cell and I can export into AutoCAD and duplicate more if I need to.
    •   AltAdvertisment
    Points: 269, Level: 3
    Oct 2017
    269
    you can change the material of those part into vacuum as well.
