Results 1 to 5 of 5
    Full Member level 4
    Points: 1,681, Level: 9
    Sep 2014
    india
    214
    1,681
    9
    Data transmition serielly by by 8051 through rf module.
    Dear All,
    I want to transmit data serielly by using Rf module 433mhz.I have made circuit as follow in proteus.As i press key in transmitter side then data is not seen in reciever 8051 port.pls chk & help.
    Thks,
    Tepu
    Transmitter code:
    //-----------------Program for wireless Home Automation using cheap ass 413MHz RF module
    //-----------------Target controller family: 8051
    //-----------------Programmer: Moses Okoroafor
    //-----------------Company: Pearl Electronics Nigeria.
    //-----------------Date started: 27/04/2017
    #define OFF 1
    #define ON  0
    #include
     //-----------PORT TO VARIABLE ASSIGNMENT--------------------------
    sbit BUT1 = P3^2;
    sbit BUT2 = P3^3;
    sbit BUT3 = P3^7;
    sbit LED1 = P3^5;
    sbit LED2 = P3^4;
    //-------------PROTOTYPE DECLARATION-------------------------------
    void delay(unsigned int ms);
    void UART_Init();
    void UART_TxChar(char ch);
    void transmit(int datum);
    bit i,j,k;
    //-------------MAIN PROGRAM STARTS HERE----------------------------
    void main()
    	i = j = k = 1;
    	EA = 0;
    	P1 = 0X3F; P3 = 0XFF;                    // shows '0' on the 7 seg on startup
    	delay(300);
    	LED1 = LED2 = ON;
    	delay(1000);
    	LED1 = LED2 = OFF;
    	delay(100);
    	UART_Init();
    	while(1)
     if (!BUT1)                                           //button for one light
        {delay(30);
          if(!BUT1)
    				j = ~j;
    				if(j==0)
           { transmit(0x01); LED1 = ON;  if(k==0) P1 = 0X5b; else P1 = 0x06;}               //when bits are 0, lights come ON
    				 else {transmit(0x09);LED1 = OFF; if(k==1)P1 = 0X3F; else P1 = 0x06;}
    				delay(300);
    if (!BUT2)                                           //button for the second light
        {delay(30);
          if(!BUT2)
    				k = ~k;
    				if(k==0)    {transmit(0x03); LED2 = ON; if(j==0)P1 = 0X5B; else P1 = 0X06;}                          //lights ON
    				else     {transmit(0x06); LED2 = OFF;   if(j==0)P1 = 0x06; else P1 = 0X3F;}
    				delay(300);
    if (!BUT3)                                         // reset
        {delay(30);
          if(!BUT3)
    				i = ~i;
    				if(i==0) {transmit(0x02); LED1 = LED2 = ON; }
    				else     {transmit(0x0F); LED1 = LED2 = OFF;}
    				delay(300);
    //---------------FUNCTION BODY DEFINITION--------------------------------------
    void delay(unsigned int ms){                      //generate one millisecond delay
      unsigned int i,j;
      for	(i=0; i
    Reciever code:
    #define OFF 1
    #define ON  0
    #include
    sbit LED1 = P1^0;
    sbit LED2 = P1^1;
    void UART_Init();
    char UART_RxChar();
    void receive();
    void main()
    		LED1 = LED2 = ON;
    	delay(1000);
    	LED1 = LED2 = OFF;
    	delay(100);
    	UART_Init();
    	while(1)
    		receive();
    //---------------DEFINITION OF FUNCTIONS----------------------------------
      unsigned int i,j;
      for	(i=0; i
    Last edited by andre_teprom; 10th October 2018 at 12:45. Reason: convert pucture from BMP to PNG (viewable on the browser)
    •   AltAdvertisment
    Points: 28,512, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,475
    28,512
    41
    Blog Entries
    Re: Data transmition serielly by by 8051 through rf module.
    Didn't you note that you have not implemented the receive() function at the receive side ?
    You have just the prototype and the the function called at the main, nothing else.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   AltAdvertisment
    Full Member level 4
    Sep 2014
    india
    214
    1,681
    9
    Re: Data transmission serially by 8051 through rf module.
    I could'nt attach complete code.As i copy & paste full code???
    •   AltAdvertisment
    Nov 2006
    Brazil
    8,475
    28,512
    41
    Blog Entries
    Click on "Go Advanced" button, right below the "Quick Reply" panel.
    There you can find option to attach compressed files.
    Full Member level 4
    Sep 2014
    india
    214
    1,681
    9
    Thank you for reply.Here is my code.
