+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 3
    Points: 57, Level: 1
    Join Date
    Oct 2018
    Posts
    Points
    57
    Level
    How to drive a 1MHz Ultrasound-TD1000KA
    Hi guys,
    I want to measure the Sediment of water. So I chose a 1Mhz Ultrasonic Transducer sensor with the ability to work underwater and also can recognize the sediment under water.
    The output of the sensor is analog, but I need a driver to transfer to digital.
    I need your help to suggest me what should i do. How can I prepare an electrical circuit? Is there anyone know what's the best way?
    This is the link of the specification of the sensor.
    http://chinaultrasound.com/product/1...ment-td1000ka/
    Thanks so much.
    Mehran
    •   AltAdvertisment
  2. #2
    Super Moderator
    Points: 50,883, Level: 55
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    12,500
    Points
    50,883
    Level
    55
    Re: How to drive a 1MHz Ultrasound-TD1000KA
    Quote Originally Posted by mehran65 View Post
    The weblink has sample output (Sensitivity test). It looks as though drawn by an oscilloscope.
    Do you want an analog-to-digital converter? Likely its conversion rate needs to be 1 MHz.
    Or do you want a driver which applies AC to the transducer, at 1 MHz and voltage as high as 300V, as listed in the specs?
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Newbie level 3
    Join Date
    Oct 2018
    Posts
    Points
    57
    Level
    Quote Originally Posted by BradtheRad View Post
    Thanks for answering.
    Actually, I want to measure the level of water of a tube with about 30 cm in diameter. and also Sediment of water of the tube.
    I bought 2 type of this model sensor, and want to understand the amount of water of the tube and also the sediment that stores end of the tube. Then check the results on an HMI. So, the output of sensors is analog. I should set an analog-to-digital converter between sensors and HMI. But I don't know how can I do that. maybe a driver with a digital output can be useful.
    The COM port of my HMI is RS232/485.
    There are some electrical circuits that work until 40kHZ but my sensors are 1MHz.
    •   AltAdvertisment
  4. #4
    Super Moderator
    Points: 252,660, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,014
    Points
    252,660
    Level
    100
    As already mentioned by Brad, the sensor has no output if not driven by an appropriate echo sounder circuit. It involves a high voltage pulse generator and receiver circuit, usually a dynamic compression amplifier and rectifier. Its analog output may be digitized and processed with a time reference to the transmitted pulse. To generate digital data that can be read by a HMI, a microcontroller or signal processor is required and somebody has to develop the software. Or try to get hold of readymade echo sounder electronics outputting depth profiles.
  5. #5
    Newbie level 3
    Join Date
    Oct 2018
    Posts
    Points
    57
    Level
    yes, you are right. Because these are just sensor and they need a converter to work.
    Can I use this module for my project?
    https://www.jahankitshop.com/getatta...5&Type=Product
    Is it possible to replace the sensor with mine? I think the difference between them is frequency.
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,014
    Points
    252,660
    Level
    100
    A 40 kHz echo sounder circuit doesn't work for different frequencies, it needs complete redesign.
    I also believe that a simple design like this isn't able to distinguish layered echo from sediment/solid ground.
    •   AltAdvertisment
  7. #7
    Newbie level 3
    Join Date
    Oct 2018
    Posts
    Points
    57
    Level
    Really? is there any commercial electrical circuit for this type of sensor? (1MHZ)
    I searched that these sensors are usefully in fish founding, so I think it's possible to find out the storage sediment under water.
    Do you have a better idea for changing the manner? Actually, I want to measure the amount of water that exists on a tube (30cm diameter and 6 m hight). But the water isn't clean and consist of mud, sand,.... so there is some sediment at the bottom of the tube. I have the hight of the pipe and first and endpoint and should measure the level of water and the level of sediment to calculate the amount of water. Is there a better way to measure as non-contacted?
