Results 1 to 9 of 9
    Junior Member level 1
    Points: 196, Level: 2
    Oct 2018
    18
    196
    Noise calculation using hspice
    How many types of noise can we calculate using hspice?
    I am focussing on cmos inverter circuit.
    I have pre and post(with RC components) circuit file ,a testbench, model file.
    Noise data is getting published in the output lis file.
    I am not able to figure out actual noise calculated as there are so many thing getting dumped in lis output file .
    I am not working on any tool,only commands on linux .
    Can anyone suggest calculation of noise of inverter using hspice?
    Points: 15,092, Level: 29
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,285
    15,092
    29
    Re: Noise calculation using hspice
    Quote Originally Posted by Knowledge.seeker View Post
    What do you want to mean ?
    Use ".noise".
    •   AltAdvertisment
    Oct 2018
    18
    196
    Quote Originally Posted by pancho_hideboo View Post
    I mean which type of analysis : transient analysis,AC analysis or DC analysis and noises like: flicker,shot
    Use ".noise".
    Used this .my code is below:
    .PROBE V(ZN) V(A1)
    .PROBE V(ZN) V(A2)
    .AC lin 1000 1HZ 1GHZ
    .NOISE v(ZN) VA1 VA2 1000
    .PRINT ONOISE INOISE
    output file generated with this code is *.lis
    it has lot of data about what models we have used,values of technology parameters ands noise data also.
    Question is how can i verify that the noise is coming though analysis is the correct one.?
    Liberty file does not have noise data on which i am working .
    Oct 2006
    Real Homeless
    2,285
    15,092
    29
    It can not be true.
    Show me true netlist.
    ".PRINT ONOISE INOISE ".
    Use correct terminology.
    •   AltAdvertisment
    Oct 2018
    18
    196
    It can not be true.
    Done this.
    I am using correct methodology.using nangate libraries of 45nm technology .These don't have noise data.
    Oct 2006
    Real Homeless
    2,285
    15,092
    29
    Can you understand a meaning of "methodology" ?
    "Liberty” does not mean "Library"
    Thermal Noise and Channel-Noise are included in simulation.
    However Fricker Noise is not included in your situation.
  7. #7
    Oct 2018
    18
    196
    Sorry that was misprinted, Liberty does not have noise data or noise is written with some other identifier in the liberty which i am not able to figure out.
    I have seen noise data in ccs liberty files but not in nldm.
    Does noise can be calculated for nldm or ccs only. ?
    •   AltAdvertisment
  8. #8
    Oct 2006
    Real Homeless
    2,285
    15,092
    29
    What relation do they have regarding HSPICE ?
    Can you understand things correctly ?
  9. #9
    Oct 2018
    18
    196
    i am taking noise data in liberty files as reference for my calculation results using simulator hspice.
    I am trying to calculate noise with nldm method using hspice.
