Results 1 to 8 of 8
    Points: 31,050, Level: 42
    Sep 2008
    cambridge
    6,481
    31,050
    42
    Wish to buy heatsink from Fischer
    Hi
    We wish to buy a couple of these "SK469 35 STS" heatsinks from Fischer but they are not in stock anywhere.
    Fischer have not responded to my eamil.
    Do you know how we can buy them?
    https://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/A04/Extruded%20heatsinks%20for%20PCB%20mounting/VA/SK46935STS/$productCard/dimensionParameters/index.xhtml
    •   AltAdvertisment
    Full Member level 6
    Points: 3,336, Level: 13
    Sep 2013
    385
    3,336
    13
    Re: Wish to buy heatsink from Fischer
    Treez this part having high lead time, you can check with their worldwide distributers someone having stock !!
    Otherwise you can select another vendor heat sink thermal resistance is 13K/W or 13C/W
    https://www.fischerelektronik.de/en/...ors-worldwide/
    http://www.anglia-live.com/products/...tsink-pcb-35mm
    •   AltAdvertisment
    Points: 15,446, Level: 29
    Nov 2012
    2,844
    15,446
    29
    I am not so sure, but did you try china suppliers? I see that heat sinks cost an arm and a leg!
    •   AltAdvertisment
    Points: 251,373, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,775
    251,373
    100
    You can send a request in the online portal. Had no problems to purchase heatsinks from Fischer yet.
    Advanced Member level 2
    Points: 4,397, Level: 15
    Feb 2014
    577
    4,397
    15
    That heatsink isn't particularly special. I can think of a few on digikey that would fill a similar role.
    Digikey lets you search by the type of package cooled and there are dozens for TO-220.
    Sep 2008
    cambridge
    6,481
    31,050
    42
    Re: Wish to buy a heatsink from Fischer
    Do you think it will be possible to easily solder the solder tab on the SK 469 35 STS heatsink?.....
    https://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/A04/Extruded%20heatsinks%20for%20PCB%20mounting/VA/SK46935STS/$productCard/parameters/index.xhtml
    ...surely the soldering iron's heat will just get absorbed up into the heatsink itself?
    •   AltAdvertisment
  7. #7
    Full Member level 6
    Sep 2013
    385
    3,336
    13
    Treez, The solder pin of heat sink is very small it having 1.3mm diameter and 3.5mm length and also pin is attached to heat sink by press fit of other method. So the chances of heat absorption during soldering process is very less. the soldering tip size is bigger than pins. You can solder even 50W soldering iron.
  8. #8
    Nov 2012
    2,844
    15,446
    29
    It is there only to provide mechanical or physical support. Nothing will happen if you leave it unconnected or hanging.
    However, it may be good to solder it if the PCB is being mounted on structure that is prone to vibrations. If the heat sink is unsupported, lots of vibration energy (which is proportional to the mass) will go into the legs of the transistor (and that is hardly desirable).
    Yes, to solder that pin you may need a power soldering iron (40-60W) and keep a large pad to support the beast.
