Results 1 to 3 of 3
    Points: 378, Level: 4
    Jul 2017
    33
    378
    itoa Function in C : How to read all DestinationBuffer values (int) into String Forma
    For hardware implementation, I am writing this function to read the data in Hercules. In Hercules, integer data can be read in string format. So, i have tried itoa conversion in XSDK. I am running counter module for e.g. N times. That N number of data should be converted into String from int and should read in Hercules.
    I have tried with below code but single data i am able to read. How to put loop for N times for DestinationBuffer.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    char buf[32] = {0};
    extern u32 DestinationBuffer[10];              // Global
    int transfer_data() {
        return 0;
    char *itoa(int val, int base)
     int i = 30;
    for(; val && i ; --i, val /= base)
    buf[i] = "0123456789abcdef"[val % base];
    return &buf[i+1];
    err_t recv_callback(void *arg, struct tcp_pcb *tpcb,
                                   struct pbuf *p, err_t err)
        int i,j,Status;
        Status=aurora_rx_main();         ///FUNCTION CALL
        for(i=0;i<10;i++)
            xil_printf(" Data:%d,",DestinationBuffer[i]);
        int base=10; // here 10 means decimal
      char *result={0};
      result= itoa(DestinationBuffer[0],base);    //// How to make it into loop to read all the DestinationBuffer values into String in Hercules. Now, i am able to read only 0th position values
        if (!p) {
            tcp_close(tpcb);
            tcp_recv(tpcb, NULL);
            return ERR_OK;
        /* indicate that the packet has been received */
        tcp_recved(tpcb, p->len);
        if (tcp_sndbuf(tpcb) > 10) {
            err = tcp_write(tpcb,result,10,1);
        } else
            xil_printf("no space in tcp_sndbuf\n\r");
        /* free the received pbuf */
        pbuf_free(p);
        return ERR_OK;
    Data stored in DestinationBuffer should be converted into string using itoa function.
    •   AltAdvertisment
    Points: 27,840, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,305
    27,840
    40
    Blog Entries
    Re: itoa Function in C : How to read all DestinationBuffer values (int) into String F
    You have defined the return type as err_t which is likely a numeric value. Instead, you should return not only the address of the first character of the string, but also its length.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   AltAdvertisment
    Advanced Member level 3
    Points: 6,675, Level: 19
    Jan 2015
    966
    6,675
    19
    I think your 'itoa' function is wrong in that it will:
    - write the characters in the reverse order into the 'buf' array
    - not null terminate the string
    - pass back a pointer to the last character of the string, not the first
    Try using pencil and paper with 'val'of (say) 23 and 'base' of 10 - alternatively just write a small program to let you step through your code to see what is really is doing.
    As for your question, you have a 'for' loop just above where you step 'i' from 0 to 9 - why not use similar code to print out each value or put the code to print each value into that loop (perhaps no need for an array in that case).
    I recommend that you look at some of the many code examples on the Internet for the 'itoa' function - why reinvent the wheel.
    Susan
