Results 1 to 9 of 9
    Newbie level 3
    Points: 24, Level: 1
    Oct 2018
    24
    Analog fast peak detector
    I would like to build analog fast peak detector.
    Signal to measure: PPM - 10ns pulses with 250ns repetition (4MHz), amplitude from 10mV to 5V.
    How circuit I can use to resolve this problem.
    I tested OPA615 but without good results - works witch pulses above 100ns.
    I don't need a very high precision and fast response.
    Points: 74,927, Level: 66
    Apr 2014
    15,196
    74,927
    66
    Re: Analog fast peak detector
    Show your circuit.
    You want a peak detector for 10ns pulses. 10ns is fast.
    So what do you mean with "no fast response"?
    Newbie level 3
    Oct 2018
    24
    I do not need a system that responds quickly to changing a single pulse. The system does not have to be precise. An error of 5% is acceptable to me.
    With 22pF10ns pulse
    With 1nF 10 ns pulse
    Circuit understands amplitude - where is the problem?
    With 1nF and 500ns works.
    Points: 18,871, Level: 33
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,643
    18,871
    33
    Do you mean an analog peak hold detector?
    Zapper
    Curmudgeon Elektroniker
    Points: 256,580, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,775
    256,580
    100
    The 22 pF waveform doesn't make sense, something is apparently not working, wrong diode type, supply voltage range, whatsoever.
    Please give complete information, actual circuit schematic, used parts, probed nodes.
    Points: 14,529, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,418
    14,529
    29
    What is NOT shown in your waveforms is the actual sample/hold signal. It may be that the timing is a few ns off.
    With wide pulses, this may not be a problem. However, 10 ns is fast, and the s/h pulse requires to be timed very precisely, and considering the propagation delays.
    Show the waveforms you including the s/h signal.
    My batteries are recharged by "Helpful Post" ratings.
  7. #7
    Newbie level 3
    Oct 2018
    24
    Quote Originally Posted by schmitt trigger View Post
    I'm using OPA615 as a peak detector witch aplication note circuit. I don't use s/h signal. In my circuit pin 7 "HOLD CONTROL" is not connected.
  8. #8
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,643
    18,871
    33
    Why are you using the circuit designed for plus and minus peak signals?
    Zapper
  9. #9
    Points: 279, Level: 3
    Jan 2018
    7
    279
    Quote Originally Posted by elektrov View Post
    How about using 2 x LTC6752 in a pulse stretch / one shot circuit as illustrated in datasheet?
    c0x
