+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Newbie level 3
    Points: 24, Level: 1
    Join Date
    Oct 2018
    Posts
    Points
    24
    Level
    Analog fast peak detector
    I would like to build analog fast peak detector.
    Signal to measure: PPM - 10ns pulses with 250ns repetition (4MHz), amplitude from 10mV to 5V.
    How circuit I can use to resolve this problem.
    I tested OPA615 but without good results - works witch pulses above 100ns.
    I don't need a very high precision and fast response.
  2. #2
    Super Moderator
    Points: 69,467, Level: 64
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    14,187
    Points
    69,467
    Level
    64
    Re: Analog fast peak detector
    Show your circuit.
    You want a peak detector for 10ns pulses. 10ns is fast.
    So what do you mean with "no fast response"?
    Klaus
    Please don´t contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    •   AltAdvertisment
  3. #3
    Newbie level 3
    Join Date
    Oct 2018
    Posts
    Points
    24
    Level
    I do not need a system that responds quickly to changing a single pulse. The system does not have to be precise. An error of 5% is acceptable to me.
    Click image for larger version.
    With 22pF10ns pulse
    With 1nF 10 ns pulse
    Circuit understands amplitude - where is the problem?
    With 1nF and 500ns works.
    •   AltAdvertisment
  4. #4
    Advanced Member level 5
    Points: 18,360, Level: 32
    Achievements:
    7 years registered
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,562
    Points
    18,360
    Level
    32
    Do you mean an analog peak hold detector?
    Zapper
    Curmudgeon Elektroniker
    •   AltAdvertisment
  5. #5
    Super Moderator
    Points: 251,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,778
    Points
    251,412
    Level
    100
    The 22 pF waveform doesn't make sense, something is apparently not working, wrong diode type, supply voltage range, whatsoever.
    Please give complete information, actual circuit schematic, used parts, probed nodes.
  6. #6
    Points: 14,187, Level: 28
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    Posts
    2,369
    Points
    14,187
    Level
    28
    What is NOT shown in your waveforms is the actual sample/hold signal. It may be that the timing is a few ns off.
    With wide pulses, this may not be a problem. However, 10 ns is fast, and the s/h pulse requires to be timed very precisely, and considering the propagation delays.
    Show the waveforms you including the s/h signal.
    My batteries are recharged by "Helpful Post" ratings.
    If you feel that I've helped you, please indicate it as a Helpful Post
  7. #7
    Newbie level 3
    Join Date
    Oct 2018
    Posts
    Points
    24
    Level
    Quote Originally Posted by schmitt trigger View Post
    I'm using OPA615 as a peak detector witch aplication note circuit. I don't use s/h signal. In my circuit pin 7 "HOLD CONTROL" is not connected.
    •   AltAdvertisment
  8. #8
    Achievements:
    7 years registered
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,562
    Points
    18,360
    Level
    32
    Why are you using the circuit designed for plus and minus peak signals?
    Zapper
  9. #9
    Points: 168, Level: 2
    Join Date
    Jan 2018
    Posts
    7
    Points
    168
    Level
    Quote Originally Posted by elektrov View Post
    How about using 2 x LTC6752 in a pulse stretch / one shot circuit as illustrated in datasheet?
    c0x
