msdarvishi
Full Member level 4
Dear all,
I am working with Vivado 2017.3 targeting a KC705 evaluation board (with Kintex-7 xc7k325ffg900 FPGA).
I have block design omprised of a DDR3, an AXI DMA and a BRAM connected through AXI Interconnect all of them controlled by a Microblaze.
My Objectives :
a) I want to write some data to the DDR3 with Microblaze through a C code writtenin SDK ---> This part was successfull.
b) Then, I want to read back those data from DDR3 and write them to the BRAM through an AXI DMA connected to a AXIStream FIFO. ----> The connections are as shown in the attached photo of my design and the bitstream was generated successfully.
c) I wrote a code in SDK in C to write some data to first 16 addresses of DDR3 which was successfullbecause when I verify the content of DDR3 via Microblaze, my written data are there.
d) finnally, in my C code I have defined a function to read data fom DDR3 into the AXI DMA ----> My problem is hear when I read the content of the first address in AXI DMA, it contains ONLY 16 bits of my data instead of 32-bit written data in it. As you see in the XSDB result and also UART result, instead of the value 0xBABABEE0 writtnenin the first AXI DMA address (0x41E00000), I receive 0xBABA3002 !!!!
For more clarification, I put the schematic of my design, my C code in SDK and the results shown on UART and XSDB.
Can anyone help me to resolve this problem? I am really confused! Thank in advance for your kind replies and helps.
Bests,
Daryon
My design schematic : Attachedsystem.pdf file View attachment system.pdf
My C code written in SDK :
The result shown on UART Interface :
The result shown by XSDB :
My Objectives :
Bests,
Daryon
/***************************** Include Files *********************************/
#include "xparameters.h"
#include <xil_printf.h>
#include <stdio.h>
#include "xil_exception.h"
#include "xuartlite.h"
#include "xbram.h"
int DDR3datawriting( int *ddr3_addr1, int *ddr3_addr2, int *ddr3_addr3, int *ddr3_addr4, int *ddr3_addr5, int *ddr3_addr6, int *ddr3_addr7, int *ddr3_addr8, int *ddr3_addr9, int *ddr3_addr10, int *ddr3_addr11, int *ddr3_addr12, int *ddr3_addr13, int *ddr3_addr14, int *ddr3_addr15, int *ddr3_addr16);
int DDR3datareading( int *dma_addr1, int *ddr3_addr1);
/************************** Variable Definitions *****************************/
//Global variables
//unsigned int *ddr3_addr1, *ddr3_addr2, *ddr3_addr3, *ddr3_addr4, *ddr3_addr5, *ddr3_addr6, *ddr3_addr7, *ddr3_addr8, *ddr3_addr9, *ddr3_addr10, *ddr3_addr11, *ddr3_addr12, *ddr3_addr13, *ddr3_addr14, *ddr3_addr15, *ddr3_addr16;
int main()
//Local variable
int Status;
int ddr3_addr1, ddr3_addr2, ddr3_addr3, ddr3_addr4, ddr3_addr5, ddr3_addr6, ddr3_addr7, ddr3_addr8, ddr3_addr9, ddr3_addr10, ddr3_addr11, ddr3_addr12, ddr3_addr13, ddr3_addr14, ddr3_addr15, ddr3_addr16;
int dma_addr1;
// Writing data into DDR3 memory
Status = DDR3datawriting(&ddr3_addr1, &ddr3_addr2, &ddr3_addr3, &ddr3_addr4, &ddr3_addr5, &ddr3_addr6, &ddr3_addr7, &ddr3_addr8, &ddr3_addr9, &ddr3_addr10, &ddr3_addr11, &ddr3_addr12, &ddr3_addr13, &ddr3_addr14, &ddr3_addr15, &ddr3_addr16);
//Checking the validity of returned variables value to the main function
xil_printf("\n\r****** Returned valued of ddr3_addr1 to the main() function = %x\n\r",ddr3_addr1);
xil_printf("\n\r The address of ddr3_addr1 = %x\n\r", &ddr3_addr1);
// Reading data from DDR3 into the AXI DMA (axi_dma_0)
Status = DDR3datareading(&dma_addr1,&ddr3_addr1);
//End of program
return Status;
//unsigned int ddr3_addr1, ddr3_addr2, ddr3_addr3, ddr3_addr4, ddr3_addr5, ddr3_addr6, ddr3_addr7, ddr3_addr8, ddr3_addr9,ddr3_addr10,ddr3_addr11,ddr3_addr12,ddr3_addr13,ddr3_addr14,ddr3_addr15,ddr3_addr16;
xil_printf("\n\rStarting to write some data into DDR3 memory...\n\r");
xil_printf("The BaseAddress for DDR3 Memory is 0x8000_0000\n\r");
//ddr3_addr1 = *(int*)0x80000000;
//ddr3_addr1 = 0xDEADBEE0;
*ddr3_addr1 = *(int*)0x80000000 = 0xBABABEE0;
*ddr3_addr2 = *(int*)0x80000004 = 0xDEADBEE1;
*ddr3_addr3 = *(int*)0x80000008 = 0xDEADBEE2;
*ddr3_addr4 = *(int*)0x8000000C = 0xDEADBEE3;
*ddr3_addr5 = *(int*)0x80000010 = 0xDEADBEE4;
*ddr3_addr6 = *(int*)0x80000014 = 0xDEADBEE5;
*ddr3_addr7 = *(int*)0x80000018 = 0xDEADBEE6;
*ddr3_addr8 = *(int*)0x8000001C = 0xDEADBEE7;
*ddr3_addr9 = *(int*)0x80000020 = 0xDEADBEE8;
*ddr3_addr10 = *(int*)0x80000024 = 0xDEADBEE9;
*ddr3_addr11 = *(int*)0x80000028 = 0xDEADBEEA;
*ddr3_addr12 = *(int*)0x8000002C = 0xDEADBEEB;
*ddr3_addr13 = *(int*)0x80000030 = 0xDEADBEEC;
*ddr3_addr14 = *(int*)0x80000034 = 0xDEADBEED;
*ddr3_addr15 = *(int*)0x80000038 = 0xDEADBEEE;
*ddr3_addr16 = *(int*)0x8000003C = 0xDEADBEEF;
xil_printf("\n\r Data written at 0x80000000 is %6x\n\r",*ddr3_addr1);
xil_printf("\n\r Data written at 0x80000004 is %6x\n\r",*ddr3_addr2);
xil_printf("\n\r Data written at 0x80000008 is %6x\n\r",*ddr3_addr3);
xil_printf("\n\r Data written at 0x8000000C is %6x\n\r",*ddr3_addr4);
xil_printf("\n\r Data written at 0x80000010 is %6x\n\r",*ddr3_addr5);
xil_printf("\n\r Data written at 0x80000014 is %6x\n\r",*ddr3_addr6);
xil_printf("\n\r Data written at 0x80000018 is %6x\n\r",*ddr3_addr7);
xil_printf("\n\r Data written at 0x8000001C is %6x\n\r",*ddr3_addr8);
xil_printf("\n\r Data written at 0x80000020 is %6x\n\r",*ddr3_addr9);
xil_printf("\n\r Data written at 0x80000024 is %6x\n\r",*ddr3_addr10);
xil_printf("\n\r Data written at 0x80000028 is %6x\n\r",*ddr3_addr11);
xil_printf("\n\r Data written at 0x8000002C is %6x\n\r",*ddr3_addr12);
xil_printf("\n\r Data written at 0x80000030 is %6x\n\r",*ddr3_addr13);
xil_printf("\n\r Data written at 0x80000034 is %6x\n\r",*ddr3_addr14);
xil_printf("\n\r Data written at 0x80000038 is %6x\n\r",*ddr3_addr15);
xil_printf("\n\r Data written at 0x8000003C is %6x\n\r",*ddr3_addr16);
xil_printf("\n\r-----------------------------------------------------------------------\n\r");
return *ddr3_addr1;
int DDR3datareading(int *dma_addr1, int *ddr3_addr1)
//dma_addr2,dma_addr3,dma_addr4,dma_addr5,dma_addr6,dma_addr7,dma_addr8,dma_addr9,dma_addr10,dma_addr11,dma_addr12,dma_addr13,dma_addr14,dma_addr15,dma_addr16;
xil_printf("\n\rStarting to read some data from DDR3 memory into the AXI DMA...\n\r");
xil_printf("The BaseAddress for AXI DMA is 0x41E0_0000\n\r");
//*dma_addr1 = *(int*)ddr3_addr1;
//*(int*)0x41e00000 = *(int*)ddr3_addr1;
*dma_addr1 = *(unsigned int*)0x41e00000 = *ddr3_addr1;
xil_printf("\n\r Data read from 0x41E00000 is %6x\n\r",*dma_addr1);
xil_printf("\n\r new value of 0x41E00000 is %6x\n\r",*(int*)0x41e00000);
return *dma_addr1;
