+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 3
    Points: 406, Level: 4
    Join Date
    May 2017
    Posts
    26
    Points
    406
    Level
    Dc to dc buck converter for solar panel
    Hello guys, if I wanted to design a dc to dc buck converter for solar panel, which MOSFET should I choose? The panel is 3w, 12v. And what if I test the buck converter with LED rather than rechargeable battery? Is it work?
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 80,392, Level: 69
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    16,308
    Points
    80,392
    Level
    69
    Re: Dc to dc buck converter for solar panel
    * a battery needs a charge controller
    * a LED usually needs a constant current source.
    I´d say you can´t use one controller for the other load.
    Regarding MOSFET: I assume (hope) you use a dedicated IC for this. Then usually in the datshett you find information how to choose MOSFET. Please also read related application notes.
    Btw: you are not the first one to build circuits like this, thus there are a lot of example circuits around. No need to re-invent the wheel.
    Klaus
    Please don´t contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    •   AltAdvertisement
  3. #3
    Advanced Member level 5
    Points: 34,003, Level: 45
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    7,062
    Points
    34,003
    Level
    45
    well you could try the LT8490 which does maximum power point tracking for you, so that you can squeeze max energy out of those panels...no matter what the light levels are..
