Hi everyone!
I have a routing issue in Innovus.
I've made all previous steps before the last one - routing.
As you can see on the first image, there aren't connections between ports and nets. At the same time, there are connections between another ports and nets (second image). How could it be?
In that case i can't make LVS in Virtuoso because of missing ports in layout netlist.
What should i do to solve that problem?
That you.
Click image for larger version.
